damaged bumper
damaged bumper
what is the difference between a bumper
and a bumper cover
in pictures they look exactly the same to me, but there has to be a diffference because there is a significant difference in price
and a bumper cover
and a bumper cover
and a bumper cover
my car slipped of the road because of ice and hit the bumper hit the ground which cracked a little bit of the side and dented it a bit too ... in different areas
im not sure if that is fixible
Bumper Repair
The cracks are definitely fixable. You just need to know what to use. If there are cracks in the actual plastic you can get a 2 part epoxy made specifically for bumper repair. You sand the area smooth and widen the crack to give the epoxy a place to go and grab onto. After it dries it will be hard as a rock. At this point you can sand it down smooth, spray flexible primer over the area, sand that smooth, wash the area with plenty of water, let it dry, spray your basecoat color custom matched for your car, and finally spray your clearcoat with clear coat blender. This will give you a professional repair without going to a bodyshop and spending $500 to get it fixed. It makes for a nice DIY for all you weekend warriors out there.
-Mike
-Mike
www.drippinwet.com
he is right, alot of cracks can be fixed they make bumper patch kits, apply it on the back side, v out the crack and use some flexible filler, color blend or paint the bumper depending on how much accross is damaged that has sealer/primer on it
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
