Custom Headlights need help wiring info
Old Jan 23, 2011 | 06:22 PM
350TLS's Avatar
jus got my headlights done with JNC..im trying to connect the halos to a 12v source..i wanted the halos to turn on when the engine is on and off when the engine is off..does anybody know which wiring do i need to use for that layout?
2007 TL Type S
Old Jan 23, 2011 | 08:21 PM
TlYungGun9's Avatar
I would wire them to an add-a-fuse. look in your owners manual for a fuse that would go on when the engine is turned on (i think with my led strips i used 21? but don't quote me on that.) i would also run it to a switch inside the cab so you can choose when you want them on our off. the other benefit is having a fuse for your halos so they won't burn out if something goes wrong. hope this helps
Old Jan 23, 2011 | 08:26 PM
stvtec's Avatar
'06 WDP TL 6MT
Also, to be clear, adding a switch means the halos will turn on/off with the engine when the switch is "on", and they will always be off (even when the key is set to ON) when the switch is "off".
Old Jan 23, 2011 | 08:54 PM
350TLS's Avatar
the fuse box!! great idea!! didnt think of that.. and definitely a switch..tnx guys ..appreciate ur input
Old Jan 23, 2011 | 09:20 PM
djmanu's Avatar
i wired my angel eyes by tapping into the parking lights. this way they turn on with the stock switch. i used the red wire on the right side and the red/blue wire on the left side. these wires come from the side parking/blinker light
Old Jan 23, 2011 | 09:24 PM
350TLS's Avatar
tnx DJ.. are the parking lights 12v?
Old Jan 26, 2011 | 12:47 AM
350TLS's Avatar
JD I tried what u said but its only on when I use the turn signal...when u said sparking/side blinker u mean the ones by the door or the front corners...I connect them to the front corners they also have red n red/blue wires
Old Jan 26, 2011 | 01:51 AM
djmanu's Avatar
the front corner ones. thats weird, i just wired these a few weeks ago when i added my angel eyes and i remembered noting those wires down for future reference
Old Jan 26, 2011 | 03:23 AM
350TLS's Avatar
the left wire is red/blue while the right is white for mine..i was trying to keep everything in the engine bay instead of running it thru the firewalll..the dreaded word "firewall" .. maybe i should try the wire that goes to the alternator.. that should work with a fuse breaker in between lol
TLrascal
Aug 3, 2018 11:00 PM
BoricuaTL
Apr 8, 2016 01:08 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
pistacio
Sep 26, 2015 09:45 AM
