Cupholder trick
Old 02-14-2005 | 07:59 PM
TLover's Avatar
Cupholder trick
Hopefully, this isn't a repost. Mods, if it is, lock it down.
Well, many people here complain that the cupholders have a death grip on their cops and are a bitch to get out. Well, after having a little disaster with my Starbucks coffee -- sadly, I must of had the first really HOT cup of Starbucks in awhile, too -- the other day, I noticed that if you twist the cup as you pull (causing the tabs to have less contact on your cup), it comes out much easier. Be careful of cardboard cups since putting that much pressure from twisting and pulling can cause the top to pop off. But for cans and hard cups, I thought I'd post that little factoid.
Old 02-14-2005 | 09:22 PM
crazymjb's Avatar
that is true with removal of most items. It has to do with newtons first law. Objects at rest tend to stay at rest, objects in motion tend to stay in a straight line motion unless acted upon by another force(also stay in motion). If you use tortion to loosen the cup first its already in motion, so pulling it out will be easierl. You can apply large amounts of force twisting something, more so then pulling it up vertically. This is also true in drift racing(peoplw who do so know what I am talking about). Thanks for the advice, Im sure many people(including me) wouldnt have thought of that until it was too late.
Old 02-14-2005 | 11:05 PM
miiipilot's Avatar
So true, I've had many "incidents" with the cup holding not letting go of my Starbucks until the lid flies off and a wave of coffee goes everyone. Twisting does help, but sometimes collapses the top of the cup.
miiipilot
Old 02-14-2005 | 11:57 PM
Contivity's Avatar
I thought i heard some other posts before where people just put extra cup so that it's easier to take the inner cup (the one with your drink)?
Old 02-15-2005 | 05:22 AM
somi2002's Avatar
ahhh.....the magic science behind the cup holder. lol.
Old 02-15-2005 | 07:55 AM
badboy's Avatar
Great tip, although I don't think I'll be using that at all.....NO DRINKS IN MY TL.
Old 02-15-2005 | 08:15 AM
rets's Avatar
Moderator Alumnus
This helps.
Old 02-15-2005 | 09:17 AM
ITL's Avatar
ITL
I do my own work.
Personally, I haven't had any qualms with the cupholders...but this is a good tip.
Old 02-15-2005 | 09:54 AM
or you could take a nail cutter and just trim the inner rubber peices a bit so you have less twisting to do and you still have that safety of the cup not falling over...
Old 02-15-2005 | 10:09 AM
sftroy's Avatar
No need to cut the rubber pieces - just use silicone spray and lube the rubber. Works like a charm AND eliminates the squeaks.
Might also want to try using a large cup to stretch the rubber slightly.
Old 02-15-2005 | 10:53 AM
Pankul's Avatar
Computer Techie Geek
Lightbulb Another Trick
the extra cup might cause the Cup holder cover not being able to shut. So here is what I did..
I used the StarBucks Brown little circular cup holders (dont know what to call them - The ones you can insert your cup into, about 2 Inches in height)
and leave those holders in the Cup Holder .. they get caught in the Rubber and tighten up a bit. Now you can easily slide any cup in and out, and those brown holders remain inside.
Old 02-15-2005 | 01:43 PM
Contivity's Avatar
Nice find... I'll give that a try...
Old 02-15-2005 | 02:27 PM
Lore's Avatar
CEO, Team Anthracite
Yes, this definitely works. That's how my coffee is served
IBankMouse
06-13-2020 12:53 PM
dirko
10-01-2015 08:45 PM
STL TL-S
09-23-2015 08:52 PM
Kevin Sami
09-22-2015 09:59 AM
dirleton
09-18-2015 05:25 PM
Quick Reply: Cupholder trick
