Cross Drilled Brake Rotors?
Team SSM
Semper Fi
Originally Posted by copter
All I see is 02-03 TL's not 04 do they use they same rotors as the 02/03's ???
Originally Posted by lovepo9e
Does anyone know of any manufacture making a Cross drilled brake rotors for the 04 TL yet.
1) cryogen'd replacements
2) embossed diamond cut (small diamond shapes cut into rotor face)
3) slotted
x-drilled rotors are not for street use (they are if you wish to fork up that $$$).
here's one site
http://www.ricambisport.com/
www.performanceplusbrakes.com They sell cross-drilled slotted rotors and pads.
Powered by Guinness
They are a popular appearance upgrade. Drilling and slotting have become so pervasive that it seems like every kit comes with one or the other now. If you're looking for a performance upgrade you should do some research first. I think you would find many racers running 'smooth faced' rotors for cost, durability, and performance reasons. I have never seen a cross-drilled rotor on a car in a major racing series.
Originally Posted by cvajs
why would you need those?? unless you're racing (not something i would do with TL oem brakes), there are better rotor types out there.
3) slotted
3) slotted
I agree OEM size cross drilled is for looks only. The holes are to reduce weight and dissipate heat but with an OEM system, it does nothing.
BBK kits, yes, they do help as the system was designed from the start to be high-performance.
Nothing wrong with getting OEM cross drilled if you want the look. Beware, some dealers don't want to touch and resurface when it's time to change pads....
That's because X-drilled rotors are for street and sloted are for racing.
Boartman
Porsche rotors are not cross drilled, the holes are cast into them as they are made. Big difference from cross drilling.
Porsche factory race cars use AP slotted rotors. These will last a 24 hour race with no issue.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
