crazy bright reverse lights???
To me, the OEM shows the bumper as brighter than the LED. I can see the OEM side better.
So, are any of these LEDs for reverse lights 'actually' brighter? I personally don't care how they look. My husband needs to reverse back through a 100' pitch black driveway that has a big boulder at the end. When I drive it, it's nearly impossible to see out the back.
I'd rather not go with HIDs as I can't find a definitive thread showing how to do it so I was interested in an LED swap but don't want to throw away the money if they don't actually throw more light down the road.
Not sure which way to go here.
To change the reverse lights you pop the trunk and u will see about a dozen clips, pop the little middle part out and then the whole clip comes out. Then there is one phillips head screw. The you pry apart the black thing around the hinges and take them off. Then just pry to the lining out and you can get to the bulbs easy, twish counter clock wise and pull them out.
For this reason, I went with a piaa bulb in my trunk for functionality. A LED in there would have been asinine.
For a brighter bulb, you want a PIAA bulb in the 921, 168, or 194 form factor. All 3 use the same socket plug, but have different form factors (921 is for a larger bulb e.g. reverse lights or interior lights, 194/168 is for a smaller bulb e.g. license lights)
Like these for example:
http://www.shopatron.com/products/pr...PIA19172/353.0
http://www.shopatron.com/products/pr...PIA19283/353.0
Not sure what the difference is between the 2, but I suspect the plasma is for a bluish look...although it could be brighter...
rockyboy
Aug 4, 2024 10:35 AM
rockyboy
Jan 25, 2016 06:00 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
