Check engine light P0171 help!!!!!!!!
Old Mar 29, 2021 | 08:10 PM
ACURATLTypes2008's Avatar
Anybody had this code before need help ASAP so I changed the front of the engine o2 sensor wasn’t that also changed the pcv wasn’t that what else could it be?
Old Mar 29, 2021 | 08:11 PM
check engine light P0171 Anybody had this code before need help ASAP so I changed the front of the engine o2 sensor wasn’t that also changed the pcv wasn’t that what else could it be?[/QUOTE]
Old Mar 29, 2021 | 09:54 PM
https://www.google.com/search?client...zine.com+p0171 Google is your friend
Old Mar 30, 2021 | 08:29 AM
peter6's Avatar
Well first thing is that P0171 is for a bank 1 sensor 1, which is upstream rear sensor. Before the cat, rear of the engine.
Old Mar 30, 2021 | 09:12 AM
TheSauceBoss's Avatar
Yeah, it sounds like you just changed the wrong sensor. Bank 1 sensor 1 isn't too hard to get to, just need to remove the front strut bar
Old Apr 3, 2021 | 10:06 AM
jcanas's Avatar
as mentioned before bank 1 is the rear bank. bank 2 is the front. sounds like you just changed the wrong sensor, try replacing the rear sensor. very highly doubt it but make sure the pins on the connector side of harness aren't corroded or deformed.
Postavshik
Aug 8, 2015 11:59 PM
acurazinefan
1G CL Problems & Fixes
Nov 13, 2008 11:52 AM
GunnmeTaLCURA04
Jan 10, 2008 03:36 PM
jazzizt
Dec 22, 2004 08:27 PM
