Changing Headlight Low Beam Bulbs
Alright, so before I get flamed, trust me I did a search. There were a couple results, but conclusively it did not help.
Recently my passenger side 8k low beam flickers, and then turns off completely. Sometimes it'll stay on for about a minute. I know the problem, I just need to swap the bulb out. If you're wondering, my friend at a body shop swapped the 8k for me before. This time I'd like to try it myself.
My question is what's the easiest way to swap out the low beams? I already have a set of 6k bulbs ready to be swapped. Can I lift the car, remove the tires and go through the fender lining? I'd prefer not to take the bumper off.
Thanks again for any of your help.
I don't think you searched. Next time try harder!
TRY THIS: https://acurazine.com/forums/3g-tl-2004-2008-93/diy-hid-bulb-change-w-o-bumper-removal-3g-garage-g-004-a-598853/
That's probably because we don't have "low beam" headlightsexactly. We have Bi-Xenon projector headlights, which means we have both HI/Low using the ONE HID bulb. Just thought I'd clarify that for you for next time
TRY THIS: https://acurazine.com/forums/showthread.php?t=598853
I'd recommend removing the front bumper..I couldn't see or feel shiz w/ the method of trying to replace the hid bulbs w/out removing the bumper.
There's no way my fingers would fit and you can't even see where the star screw bit is at...I removed the bumper and even the headlights for a simple bulb replacement.
Just some cheap aftermarket ones, lasted me a good 1.5 years.
mod please close thread
I recommend the Kaixen bulbs. Read my review here: https://acurazine.com/forums/3g-tl-photograph-gallery-96/kaixen-6000k-hid-bulbs-vs-6000k-ebay-specials-742814/.
Also, I did everything through the hood and fender linings, no need to remove the bumper. Just had to remove the battery for the driver side. Flashlight helps too.
mada51589
Jan 9, 2025 04:40 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
