change temp reading from Fahrenheit to Celsius
Hi, does anyone know if you can change all the temp displays from Fahrenheit to Celsius or visa-versa. Don't the Canadian cars use Celsius? It's probably a hidden feature.
I don't have a TL. Does the TL have a digital speed readout as one of the display options and, if so, can it be changed from MPH to KPH? Yes, I know that the inner ring of the speedo is KPH, but it's hard to read.
If I buy a TL in California, it might eventually end up in BC.
Originally Posted by Rexorg
Why do you want to change it? The temp outside is not going to change.
Originally Posted by Jss1
If you go into the navi configration menu (hold menu,map,cancel buttons for 5 seconds) you can change the region from U.S. to Canada. That should do what you want.
Ah, but I wonder what other things might change as a result.
OMG. I think I may have a coronary (not an idle threat, at my age). At last, I've discovered one little thing where Mercedes-Benz is ahead of Acura/Honda in electronic functionality.
mada51589
05-03-2022 08:54 PM
bearingman07936
01-07-2016 03:22 PM
