Ceramic Tints preventing dash cracks?
So I'm wondering if theres any opinion on ceramic window tints as a way to prevent dash crack, prevent door panel melting and general interior wear and tear. I have the black interior and it really does get hot as hell in the sun. In addition I'm getting a little nervous because i can now see the outline of the passenger airbag (lightly) in the dash. I always use a sunshade but that doesnt seem to really do too much. Was this issue solved or at least mitigated in later model years, or is it pretty consistent in all 3Gs?
Chad05TL (08-14-2019)
iWhine S/C 6MT TL
There's only so much you can do to help prevent this issue, but it will eventually happen. It's a manufacturing defect.
does it seem to be worse with earlier model years vs later or does it literally not matter? Ive got 303 on the way but here's what my passenger side looks like now.. is this the beginning of the end for my dash?
This has been discussed in depth for many years on the forums. Lots and lots and lots and lots of info, theories, rants, and such already here.
Summary:
- you can't "stop" it from happening...it is just a matter of time depending upon exposure and care
- many of us used 303 religiously and still cracked....it is possible we delayed it, but still cracked
- many of us use sun shades and still cracked
- best preventive care are clean, treat, block the sun, prevent major temp swings
To note, mine didn't crack out at the airbag. Mine started around the center speaker. Only after a year or two did the airbag finally crack out. Mine didn't crack during the summer either, it cracked over the winter months. A co-worker of mine with an '04 had his finally crack this past winter as well.
Summary:
Slpr04UA6 (08-06-2019)
Summary:
Summary:
i always use a sunshade, but this car spent its first 3 years in the Carolinas so i suppose its only a matter of time... and i am actually not totally surprised by the winter occurrences, can see temp swings in the cabin actually being worse in winter than summer
I have an '05 that spent its first few years as a Florida leased vehicle, then has spent the next 10+ years in Missouri with me. First 5 years garaged at home and at work. Next 5 mostly garaged at home, but not at work. These days....rarely garaged. Being in the central US my car is exposed to 115F max in the summer down to -10F in the winter....rarely at those extremes.
All 3G TL dash will crack eventually, but you can do something to slow down the process.
1. put a windshield run cover to reject some heat, even tho the heat still goes through your windows. Yes even with Ceramic tint... (I have it on the RL and TL-S)
2. combo of 303 and dash cover could help (I got this set up as well)
3. Avoid parking under the sun (not all of us having this luxury, I am glad my TL-S is now garage all day even I take it to work)
4. Avoid extreme temperature swing (this is unavoidable)
Once the 1st crack develop, there is no way of stopping it, I have a TL with dash crack.... Yes even parking 95% in the garage the crack appear on other area of the dash like cluster and center clock stack also I treated the whole dash with 303 and dash mat after the initial "infamous" airbag crack.
At this point if the TL-S dash crack its not the end of the world since I already did all things within my power to slow down the crack cause by design flaws.
seinfeld-bassline (08-06-2019)
interestingly, as i search more on this topic, it seems 04-06 are the hardest hit by the cracks so far, but that could just be a function of being older. Something tells me Acura never really took steps to correct the issue.
justnspace (08-06-2019)
so conclusions:
-ceramic tints will probably not stop cracking
-303 will probably not stop cracking
-sunshades and garaging the car will probably not stop cracking
-there is no stopping the cracking
-submit to the crack, as it is inevitable
but in all seriousness thanks all for input, i will take as many preventative measures as humanly possible but understand its a manufacturing defect that its just part of these cars.
To put your mind at ease my passenger airbag outline is even more noticeable than yours. However there are no cracks on my '06 and far as I know it was never garaged by previous owner.
I wonder if it's not just simply the sunlight, humidity and temp changes but physically pressing down in some way or another (phone mount, resting leg on dash, pressing on it getting in and out of seat... etc).
seinfeld-bassline (08-07-2019)
-------Tim-------
^Nun of the above.
Like said By Gus, it’s a manufacturing defect. Period.
Trust me, you can do all you want to try, the only thing I haven’t prior to the dash cracking, is tinting the whole front windshield with a UV clear, or 70%-80%...
I decided to just go with standard tints (35% side, 20% rear) and not do the windshield (wanted another $175 for 50% - legal limit). Ill use 303 and put up a sunshade but Im in CT not the south.
Tints....
Slpr04UA6 (08-09-2019)
Hell i got 5% ceramic (Suntek CIR) all around except front windshield and its still hot AF.
-------Tim-------
^exactly! It’s cause where we live! Lol!
I used sunshade all the time, and garaged at home. Still cracked at year 12.....ugh.
Had 4% on all windows except windshield. Removed after 10yrs, and went with 10%. Dash already cracked, so didn’t do windshield...
Well OP you remind me of mine good old day when I moved to TX. Yes the car original from Devan Norwalk Acura then I bought it from Liberty Honda. This pictures is the regular Suntek Carbon film, Ceramic wasn't even available yet.
Well just got my first dash crack this weekend in the same area. When I bought my TL back in 2013 the dash was perfect then towards the end of 2018 the outline of the passenger airbag started appearing like yours then bam crack, my car is garaged at home at work when I do drive her she is outside I have tinted windows and use a windshield cover, I also great the dash but still I became a statistic here in florida it gets really hot inside the car which I would say like most here is the issue (temp swings), and now a new dash is over a thousand when it used to be less then $700.00. Hope you fair better than I did and do everything possible to prevent the ugly crack issue...
cracked dashboard have been going on since the beginning of time. Some of the BMW's have a real thick, rugged, coarse material on their X5's.
I think Honda just went cheap. I dont think it was a defect as much as I think it was "old technology" or carelessness.
403 UA6
08-24-2010 12:03 PM
