Cargo Net & Liner
Old Jun 28, 2007 | 01:59 PM
waymay1305's Avatar
Cargo Net & Liner
Can the cargo net be used if you also have the plastic cargo liner? If so, how do you attach the net?
Old Jun 28, 2007 | 02:40 PM
01tl4tl's Avatar
If you can still see the round knobs on the sides- you can hook the net there
Old Jun 28, 2007 | 03:05 PM
OKNBPTL's Avatar
Boomer Sooner!
Figuring out how to rig up the "small" net is the real stumper.
I spent a good 15-20 minutes futzing around with it until I figured out a configuration I could live with (and I'm still not convinced it's "right")
Old Jun 28, 2007 | 04:54 PM
trancemission's Avatar
Regions Leader
mine is still somewhere in the garage after I fucking threw it in a fit of rage
Old Jun 28, 2007 | 05:47 PM
Will Y.'s Avatar
Registered but harmless
Do a search for "cargo nets trunk tray" to find the thread-- someone discovered that you don't need to cut any holes in the liner bottom for the nets, although some people did (I don't have the trunk tray, so i couldn't tell you from experience).
It was; I found the thread that had pictures of the cargo net setups which helped a lot. The small net should section off the corner of the trunk and have a small suspended triangular pocket.
That's not helpful from a mega-mod.
[ibbanbot.]
Old Jun 28, 2007 | 06:19 PM
SteveP66's Avatar
Kaa - Ching !!!
From: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
Same questions from me when I first got my TL. You don't have to cut your tray for the net knobs.........
Unscrew the floor ones - place cargo net back on top - screw floor nuts back on making a small hole in the liner with the screw head.
The only sucky thing is that you have to unscrew the floor nuts if you ever want to remove it to clean or vacuum.
The small net can go a couple of different ways - it's one of those things that you just have to keep on trying until you get it right or wrong...lol
Old Jun 28, 2007 | 07:05 PM
SteveP66's Avatar
Kaa - Ching !!!
Here's a good thread with pics
https://acurazine.com/forums/showthread.php?t=65547
Old Jun 28, 2007 | 07:34 PM
george3761's Avatar
2007 TL Type-S
As far as the trunk tray. Just cut a small + in the spot that the net hold downs need to poke through. Then just push the tray down over the "mushrooms" and they popup thru the small cuts you made.
Old Jun 28, 2007 | 09:13 PM
SteveP66's Avatar
Kaa - Ching !!!
Much easier to unscrew the nuts and screw them back in through the tray.....................the hole gets sealed when you screw the nut back on.
If anything should leak in the tray it will most likely leak through the + you made
Old Jun 29, 2007 | 06:59 AM
Regions Leader
[ibbanbot.]
there was no intent to be helpful. that cargo net is stupid
lland
Oct 4, 2015 04:47 PM
d.lim
Sep 15, 2015 08:54 PM
EE4Life
Sep 11, 2015 10:13 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
asahrts
Sep 4, 2015 05:55 PM
