Car drives really fast after battery reset
Old Feb 3, 2017 | 03:38 PM
DarrelP's Avatar
I have a 2007 acura tl base 91k miles and I can tell you it's pretty slow but after I disconnect the negative terminal on the battery for 5-10 mins, it performs very well and feels like I gained a 100hp. After 10-15 minutes I can punch the throttle and it won't even break traction with VSA off. My old 04 accord 4cyl accelerates faster than my TL. I cleaned the intake manifold, egr and throttle body. I also replaced spark plugs with NGK, I did the App sensor replacement and I replaced purge solenoid . I hate mechanics but I feel like even they won't figure it out. I also have no CEL light on.
Old Feb 3, 2017 | 03:40 PM
https://acurazine.com/forums/third-g...-happy-747662/
Old Feb 3, 2017 | 05:17 PM
stevemk07's Avatar
I find my car gets faster after doing an oil or atf change. Need any of those?
Old Feb 4, 2017 | 12:10 AM
DarrelP's Avatar
I did those 3k miles ago but I think I need new shift solenoids. I don't know if that would be the problem.
Old Feb 4, 2017 | 08:52 AM
sarcasm?
cuz unless you're Antman and can feel at a molecular level....
you cannot perceive any difference after an oil change... especially feeling quicker...
Old Feb 4, 2017 | 08:54 AM
there is no problem.
Modern car ECU's learn habits.
when you disconnect battery for a few mins, the ECU forgets or resets your driving habits
Old Feb 4, 2017 | 12:23 PM
stevemk07's Avatar
sarcasm?
I guess I must be antman.
Old Feb 4, 2017 | 02:43 PM
srg818's Avatar
Has anyone found any information how quickly(time/mileage) the ECU learns your driving habits? and is it a continuous adaptation of your driving habit or a one-time deal recording that sets your personal standard until you reset it again?
Old Feb 4, 2017 | 04:17 PM
eastcoastguy's Avatar
Not sure how quickly it learns but I think its a continuous adaptation to your driving.
Old Feb 4, 2017 | 05:42 PM
Roblee23's Avatar
My 99 does the same exact thing, i normally reset the computer once about every month and a half, and i instantly notice how much quick and firmer the shifts are, it feels like im driving a different car, once i reset it, i used to try to drive fast just to get the computer to adjust to spirited driving. But it never works and after about a day give or take, it goes back to driving the same way👎👎. Maybe a pcm tune can solve this while adding some power. I know our cars are different, im just stating my experience.
Old Feb 4, 2017 | 08:47 PM
Oh Sickest TL's Avatar
Jeff
sarcasm?
Fools be gaining H pees after doing some routine fluid maintenance lmfaoooooo
Old Feb 4, 2017 | 10:51 PM
DarrelP's Avatar
I think my car is messed up. I'm scared to try to beat traffic when getting on the road because there no throttle response. it takes time especially when the weather is like 75 degrees or more. I'm really starting to think honda is different from acura. I know they're the same car but honda don't do stuff like that. No matter how bad the car is. I always make sure my car runs good and I have No CEL light.
Old Feb 4, 2017 | 10:56 PM
DarrelP's Avatar
My old accord coupe 4cyl was burning and leaking oil and I still had good performance. I'm confused😕.
Old Feb 4, 2017 | 11:00 PM
Loid's Avatar
I shaved a full second off my 1/4 time by resetting the ecu in the staging lanes. By the time I picked up my slip it had reverted back to my old driving habits though..
Old Feb 4, 2017 | 11:08 PM
Try eating a salad instead of a burger and your car will go even faster!
Old Feb 5, 2017 | 01:46 AM
TacoBello's Avatar
My car doesn't change after I pull the battery. In fact, the car feels the exact same, afterwards.
Hmmm, I wonder why...
Old Feb 6, 2017 | 01:47 AM
igloo's Avatar
Talking
Maybe if you put the battery back in?
Tim Hortons=Good Coffee!
Old Feb 6, 2017 | 06:29 AM
what you're speaking of maybe considered heat soak.
heat is bad. sometimes, the car will get heat soaked and not perform as well.
it's especially noticeable in the summer months.
also, you do know that we make peak power at 6k RPM right?
when you're trying to merge, if you merge at lets say 3k RPM...you're only pushing like 100something torque.
you need to rev the ever living hell out of the car to make power!!!
I LIVE in vtec!
Old Feb 6, 2017 | 06:33 AM
kurtatx's Avatar
Azine Jabroni
Old Feb 6, 2017 | 06:35 AM
Old Feb 6, 2017 | 10:49 AM
corrado85's Avatar
Alien from Mars
I feel like if don't have a Taco Bell for 4th meal night before, my car feels very peppy the next morning.
just fyi
Old Feb 6, 2017 | 11:07 AM
TacoBello's Avatar
No, it's because I'm always on the throttle!!!
And Tim Horton's is not good coffee. Bleh. Some extremely generic, low caffeine, brown water.
TacoBello's Avatar
just fyi
What does eating me have anything to do with how fast your car is?
Old Feb 6, 2017 | 12:55 PM
SoSaysI's Avatar
BlueDriver
Maybe Get a BlueDriver or other OBD-II module and monitor engine conditions immediately after resetting the ECU and compare them to the data when the car starts feeling slower. You may be able to narrow it down to engine temp differences or something else that could be causing the power loss. Just a thought...
Old Feb 6, 2017 | 12:57 PM
^really great thoughts
Old Feb 6, 2017 | 02:03 PM
mazen222's Avatar
I feel like my car goes much faster after i do a car wash... for real...
On a serious note, all of these are true and are felt thanks to our friend Placebo.
Only way to find out for fact is to do what SoSaysI said. That's what he said and so do I say. Now it has been said!
Old Feb 6, 2017 | 02:12 PM
TacoBello's Avatar
it's not engine temps. Though that does cause the car to feel sluggish. What OP is talking about is just the ECU learning his driving habits. The car relaxes if the driver is putting around. Helps with fuel economy, etc.
The question is: how long does it take for the ECU to learn habits and how often are they recalculated?
With his car being a 5AT, I'm not surprised the ECU starts to relax... I don't know many auto drivers that are always mashing the throttle and stuff. It's much more common with a manual transmission.
Old Feb 6, 2017 | 06:08 PM
Jeff
I will say this:
I store my car for the winter, meaning the battery gets pulled. The car learns my driving habits during the first month of spring/summer. During the summer the car tends to hang in the higher rpms of second and 3rd gear because I drive it with the sport shift and tend to keep it in those "fun gears" so when I'm driving in non sport mode the car still tends to hang in those gears for me. Now when I pull battery and take the car out for this first few drives, it does not feel as peppy as its trying to re learn my sweet spots. GRADE LOGIC
Hope that makes sense..
Old Feb 6, 2017 | 08:15 PM
YungMoola15's Avatar
Try putting a body kit and JDM sticker across the windshield.
btw is this your accord?
"The car has a racing kit on it therefore it is very fast."
Old Feb 7, 2017 | 11:54 AM
you LOST all of us, yungMooooola
Old Feb 7, 2017 | 01:08 PM
WAIT, is this not a troll thread?
