Can't get OEM Type S sideskirts in KBP
ok so i ordered my type s lip kit in kbp and the dealer told me theyd get it in blue, when the kit came the sideskirts were white and everything else was blue. they ended up giving me my money back for the sideskirts and said that in NYC no one of the dealerships have the sideskirts in Kbp!... id rather get it oem colored then buy em and paint them and it doesnt end up matching,
Anyone has any kind of idea other then me buying em in silver,black or white from the dealer and then painting them over?
(ps i have a spare pair of stock sideskirts, not the type s sides but the original non kit set, that the previous owner gave me )
Try one of the vendors here. KBP might be discontinued? You might have to get the sides painted, its what I had to do. It wasn't too expensive and they are color matched perfectly. A good body shop will be able to match the paint, I wouldn't worry too much about that.
which vendor? i havent seen anything related to just the sideskirts? if its cheaper (including s/h) then 300 then id consider it but it would have to be singificantly cheaper seeing as i still have to spend like 150 to paint minumum
Bruce(AcKTL05) or Tim(oemacurapartstim). They can order any oem part you want including just the side skirts. My sides were like $267 shipped i think. Who knows, maybe one of them can get you some some KBP ones.
It makes no sense to me to make the front and rear in kbp and not the side skirts... Smh. Ok thanks for the info fellas. I hope to find it in kbp though. I'm prob not gonna install the kit any how yet with the upcoming NYC winter and snow soon anyhow. Prob gonna snow and scrape up the front lip
KBP along with a few other colors were discontinued some time ago. I'm guessing the front and rear are just what they had left for inventory of KBP lip kits. The stock side skirts on the type s flow pretty well with the front and rear lips, they have more of a flare to them than the base ones.
When I bought my ASM Type S A-spec kit I had to get the front and rear in white but the sides came in ASM. I had the front / rear lip painted silver, entire front bumper resprayed and the kit installed for $500 Canadian cash and they even waxed the car. It was well worth it and looks great - that was July 2012.
I would just get the proper aspec sides and get them painted - if it's a good shop you won't have any problems and will quickly forget that you had them sprayed.
Jon
Jon
I googled aspec sides and I don't see a difference. So I'm lost.. There are 3 versions of side skirts????? (I have a original type s) 1) original type s stock. 2) type s lip kit and 3) a spec sides?????
OP just buy some A-Spec side skirts and just get them painted.
I think you are confuse. Your first post stated that you bought the Type-S Lip Kit (assuming the Type-S A-Spec) and when you received it; there was no side skirt in your color, but they gave you a white one.
Now you are wanting to go back to the dealer to see if they have the A-Spec in KBP. They dont my friend.
You have 3 options:
1. Wait for someone in the black market to sell theirs or post a WTB thread in the BM.
2. Buy the white and have it painted.
3. Stay with your stock side skirts.
You have 3 options:
Let me put it to you like this. Acura only produces a number of these A-Spec products e.g. 100 front, 100 side, and 100 rear. Once they are bought out, they wont make any more even if they sold all the sides and had 5 front and 7 rear. Its a first come first serve deal.
Modifications will have to be made to do so since the bumpers have different overall shapes and since the Type-S rear bumper has wider exhaust outlets.
•BOTH 04-06 and 07-08 Base front lips will fit a Type-S, but modifications will have to be made
•ALL A-Spec sideskirts are the same. There is NO difference between 04-06 Base, 07-08 Base, and 07-08 Type-S A-Spec sideskirts. Part numbers and paint codes may differ but they look identical and install the same way.
•ALL 04-08 Base rear lips are the same.
NOTE:
Important Notes:
•The Type-S A-Spec front and rear pieces can fit on Base TL bumpers.
thanks for the info...that clears up alotta my confusion kinda,
NOTE:
Important Notes:
NOTE:
Important Notes:
The 07-08 base aspec front lip can fit the type-s without modifying it. There are a couple of threads on those. However, the 04-06 base front aspec does require to be modify to fit the type-s. I dont know if the type-s front aspec will fit the 04-06 base bumper; not without modifying it too. The rear will fit but you will have to cut out the exhaust garnish to get it to fit.
I am answering the ones I put in bold:
as far as my sides skirts i see that all years will fit but i should go with the A SPEC SIDES SKIRTS then.. prob flares out the most and matches the best with the type s kit
handsom-hustla
Nov 13, 2015 05:04 PM
sockr1
Oct 1, 2015 01:31 AM
