Can't belive it.
Old Dec 1, 2015 | 09:05 PM
Sal's Type S's Avatar
Can't belive it.
I just picked a set of RB Rear Big Brake kit for my 08 TL Type of Amazon. It got it for only 378! I had it on my wish list for a while and it was like over 1K. So I was ordering some other items for another project and after that I was clearing some other stuff off My wish list and came across the item and was like
then and splooge clicked it and confirmed same part number
2153-381 on the heeltoe site. Could not pass up the deal. I guess my truck engine rebuild might take just a bit longer. Post picks when they come in,.. Just had to say it. It was the last kit tho, I guess they just must of been closing the item out.
Old Dec 1, 2015 | 09:14 PM
guitarplayer16's Avatar
congrats
Old Dec 1, 2015 | 09:23 PM
MonkeyTrucker's Avatar
Life Connoisseur
Looks like another is available:
Amazon.com: RacingBrake 2152-381-0 307 mm Open Slotted Finish Rear OE Caliper Big Brake Kit for Acura TL 04-08: Automotive Amazon.com: RacingBrake 2152-381-0 307 mm Open Slotted Finish Rear OE Caliper Big Brake Kit for Acura TL 04-08: Automotive
Nevermind, I see you posted the part number of 2153-381.
Pads are $200 to replace and are thinner than stock. Not sure I'd want that annual expense. Grats I suppose.
EDIT - Dunno, the 2152-381 for $372 in the link above seems identical to the 2153-381. Strange...
There's an old rule we went by in some other forums where it wasn't the best practice to actually "brag" about items that were purchased until they were actually shipped.
Here's some info comparing the two variants from RB themselves:
http://forums.racingbrake.com/showpo...3&postcount=20
"Either kit will fit under 17' wheels, and nothing else to buy. They are 100% bolt on kits (excepting bending or trimming the dust cover behind the rotor) which actually helps to run the rotors cooler, due to better air circulation."
So, looks like another is available if anyone wants it. Better grab it before a "re-seller" jumps on it.
Old Dec 1, 2015 | 11:51 PM
Actually the pads are like 85.00 on the RB website. But the part numbers show 307mm for the 2152- and 327mm for the 2153- Either way post pics when it comes in and give head up on the install.
Old Dec 2, 2015 | 08:12 PM
Hi speed's Avatar
runnin a little boost
Is the kit for the rear? I would think larger rear brakes would cause issues with brake bias, even if used with the stock caliper. Has anyone one else run this kit on the 3G TL?
Old Dec 2, 2015 | 09:04 PM
Life Connoisseur
Yes for the rear, and I'd think you'd have to deal with proprietary brake pads thereafter this install.
Dunno, didn't realize big rear brake packages were a thing, or sought after, until OP chimed in.
To the OP the vendor you compared to is wrong in their description, that's what confused me, it's the vendor you stated you looked them up on, they've listed the kit you bought as the 307s (2153-381). It contradicts what the manufacturer states in the link I provided earlier. Not surprised in their (HT) error.
https://www.heeltoeauto.com/rb-perfo...-2153-381.html
Old Dec 3, 2015 | 02:30 AM
paperboy42190's Avatar
I'm assuming you would lose ebrake function with this kit?
As far as the brake bias goes, I think it would be affected. The braking force would be the same, but with more leverage due to increased radius. Would a bit more rear braking power be that bad? Or is the stock bias 100% perfect already?
Old Dec 4, 2015 | 09:09 PM
Well got home this afternoon and the kits came in. I ended up buying both kits off Amazon could not let a deal go by. The kits look the same at first but they do have different size rotors and the brackets for the calipers are also different. They have the corresponding rotor size. As or the parking brake the inside of the HAT is set up to keep the parking brake. I was going to install this weekend but now I have to deal with taking my car to repair shop. Some inconsiderate driver decided he needed to change lanes at last minute and hit my driver side mirror and broke it off, also have tire marks on driver side fender edges and part of bumper by wheel on my A-Spec kit. Will post pics later. One kit is a 328mm and the other is a 307.
Old Dec 4, 2015 | 10:20 PM
rockstar143's Avatar
cool find, man...in for updates.
Old Dec 4, 2015 | 10:27 PM
Here are some of the Brake pics.https://drive.google.com/file/d/0BwW...ew?usp=sharing
Will bw selling one of the kits.
Old Dec 4, 2015 | 10:57 PM
host on photobucket or something.
Old Dec 4, 2015 | 11:43 PM
Have it on my Goggle drive. Let me know it works or ill have to try something else.
Old Dec 5, 2015 | 01:34 AM
hisost's Avatar
Huh, a 328mm rotor in the rear? If I remember correctly, the type s and MT models had 310mm rotors up front; would it be fine putting larger rotors on the rear?
Either way, nice purchases!
Old Dec 5, 2015 | 10:10 AM
screaminz28's Avatar
Cant tell from the pics but are these vented rotors or solid still?
Old Dec 5, 2015 | 12:18 PM
it works if we click each individual link...
cool rotors but I agree, sounds like the sizing is a little...BIG.
Old Dec 5, 2015 | 02:10 PM
I picked up two kits. A 307mm and a 328mm I'll more than likley us the 307 to keep it better balanced.
Old Dec 5, 2015 | 02:15 PM
Do you plan on upgrading the brembos to something bigger?
these brakes look awesome!
Old Dec 5, 2015 | 02:30 PM
I already have the two piece rotors up front. Installing these will make it look even.
Old Dec 5, 2015 | 10:50 PM
They are vented
RDX10
1G RDX (2007-2012)
81
Apr 13, 2016 06:45 PM
dbarnhart
2G RDX DIY & FAQ
Dec 9, 2015 08:56 PM
Mr Airport
Dec 7, 2015 08:32 AM
GreenSpades
Dec 6, 2015 04:30 PM
ericcdong
Dec 4, 2015 01:45 PM
