Cabin Filter Replacement
Old Mar 15, 2010 | 01:42 PM
FlaskTL's Avatar
Later today I am going into my shop to get my tires balanced, rotated, and aligned. I do this every 5,000 miles when I get my oil changed sense I have lifetime on all of it. Soooooo, to get to the point my TL is at 80,000. I bought it at 57,000 2 years ago. I don't think the cabin filter has ever been changed before I bought it and I keep reading here on AZine that should change it every 30k. Is this really worth my time and money?
Not trying to sound dumb here but I just want to know the benefits of doing this.
Old Mar 15, 2010 | 02:00 PM
flyromeo3's Avatar
honestly i would go ahead and change it.
I changed mine not to long ago and was quite surprised by the junk in the filters.
The removal process is beyond easy. I had no idea how to remove it and just went ahead and did it anyway.
Next thing you know, i found the DIY and based on the steps , it was exactly as I did. So no Ph.D is required.
Old Mar 15, 2010 | 02:14 PM
LoveMyTL-S's Avatar
It's really up to you, do you want to breath clean or dirty air?
Old Mar 15, 2010 | 02:20 PM
Izzy-Type-S's Avatar
WOT in the new ATLP V2s!
I did mine at like 25k and was so glad I did. It actually makes your car smell fresh for a few days. I say I'm about do for another change out soon.
Old Mar 15, 2010 | 03:10 PM
Bearcat94's Avatar
AZ Community Team
It's probably worth your time and money, but may not be worth what a dealer or shop will charge. I've read of dealer service charging $130+. WAY too much.
DIY is like $20 for the filter and 15 - 30 minutes of your time. Only tool you need is a screwdriver and maybe a utility knife (dont' remember if there are plastic tabs to cut the first time or not).
F-130: DIY: Replacing Cabin Air Dust & Pollen Filter
https://acurazine.com/forums/showthread.php?t=87494
https://acurazine.com/forums/ramblings-12/firewall-help-123884/ Good pictures here
https://acurazine.com/forums/showthread.php?t=131831 Replacing the filter without removing the entire glove box
https://acurazine.com/forums/3g-tl-2004-2008-93/f-130-diy-2008-tl-cabin-air-filter-replacement-pics-745341/ Good detailed photos's
Old Mar 15, 2010 | 03:25 PM
SouthernBoy's Avatar
Registered Member
I do mine every year.
Old Mar 16, 2010 | 02:53 AM
Dima1978's Avatar
Nope, nothing to cut in my TL, I have put in a filter without an active element, tomorrow I am installing a baking soda filter. In my experience, the panel part that you pull out may crack or the plastic tabs may fall off if it is cold (it is possible the previous owner did it). PS Cold is ND, MN, MI, Canada, NE cold not Florida 55F cold.
Old Mar 16, 2010 | 05:32 AM
01tl4tl's Avatar
should do this every year! total DIY
When you see the filter you will understand- you've been breathing thru that!!!
Yikes~
filters with activated charcoal or baking soda or micro-allergens are better at freshening the air
Old Mar 19, 2010 | 05:16 PM
Ramrodthrusterpuppy's Avatar
Yikes~
QFT...just changed mine after 2 years....disgusting. From now on I will be changing every year religiously.
Old Mar 19, 2010 | 05:29 PM
Dino81's Avatar
Just changed mine also, ALL the fins were full of crap, including, but not limited too BIRD FEATHERS and LADYBUGS..
Defiently worth the time and money ($11.00, I think @ advance auto) easy easy easy DIY.
Old Mar 19, 2010 | 05:30 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Do it.
Old Mar 19, 2010 | 05:53 PM
AckTL05's Avatar
Former Sponsor
I did mine at 40k and it was disgusting. The part was ~17 dollars and about 20 minutes of my time. It is recommended every 15k miles / 1 year. What's 15 dollars a year for breathing fresh air?
Old Mar 19, 2010 | 07:35 PM
05TLbase's Avatar
anyone every spray any smell good on these... or is there a place i could rig one of those fragrance jar things in there?.. I havent done mine myself yet but trying to keep the dealer outta my pocket from now on
Old Mar 20, 2010 | 10:12 AM
naveenhere's Avatar
I used to drive hwy (NC/SC) a lot & the cabin filter was disgusting when replacing. I did it every 5k from during that time.
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
Skirmich
Sep 15, 2015 06:41 PM
Aleax
Sep 9, 2015 08:04 PM
