C350 vs A4 vs 3G Type S AT
Hi guys,
I just wanna compare few cars here,and which one will you guy choose and like the most???
1.2008+ C350
2.2008+ C350 4matic
3.2010+ A4 AT
4.3G Type S AT
and which one will u guys put money on if both 4 cars race??
1.2008+ C350
2.2008+ C350 4matic
3.2010+ A4 AT
4.3G Type S AT
0-60 times put the Type-S on top.
C350 - low to mid 6's.
A4 - Mid to high 6's.
Type-S - mid to high 5's.
But that's just on paper. From experience however, I can tell you that a stock A4 is not much of a threat at all. The C350 might give you a run for your money though. I still think you'll pull though.
Provided there's no work done to the A4 (which is probably unlikely in a car that new, with respect to factory warranty), the TL-S is about a second quicker (to 60) than the others.
The auto TL-S should be in the low 6's (0-60), the manual is high 5's. Which would put it door to door with the c350. It would really just be a styling preference between the two. 4matic is isn't a big deal unless you get snow. The Acura is probably more reliable and cheaper to repair.
The A4 is slooooow. I beat one... in my QX. Reality check for that guy.
Have you considered a G37?
16GS FSprt,03Max,12 335is
TL-S is pretty fast. The C350 is an absolute joy to drive though. 7-speed transmission, more low-end power, handles better than the TL. I can't comment on the A4 as I've never driven one.
I think from a dig the C350 will probably launch better and stay ahead until the TL hits the top of 1st and shifts into second gear. At that point I believe the Type-S will either pull slightly ahead of the C350 or at least be neck and neck with it.
If you want to take the away the C350's RWD advantage, I'd suggest you do a race from a very low roll; i.e. 5mph. That way you guys won't have to argue about a bad launch or being in the wrong gear at X-mph. Just a thought.
Good luck either way and stay safe bro!
P.S. - film it if you can.
bread when you gonna run me bro i wanna see how my car does against your 3g type s.
but yeah anyway i ran a 06 e350 when i was stock only had intake and atlp exhaust i took him from a dig and i pulled a couple cars on him too
Aren't E350's extremely heavy though?
justin.w13.walker
09-22-2015 02:21 PM
