Brake Rotor Screw Question
Old May 12, 2009 | 09:08 PM
shumax's Avatar
I am about to replace the pads and rotors on my '05. Can someone tell me what size of phillips head I need to remove these screws that are on the rotors? Or, even better -- what adapter would I need for a 3/8 impact wrench?
I'm just trying to buy the adapter I need for an impact wrench, or for a manual ratchet driver, before I start this project.
Thanks!
Shumax
Old May 12, 2009 | 09:09 PM
blkaspec's Avatar
Full of water...
i just used the biggest one that came with my impact wrench..sorry if that doesnt really help
Old May 12, 2009 | 09:13 PM
blkaspec's Avatar
Full of water...
ok, i checked. i used the #3 bit for my Craftsman 3/8 wrench
Old May 12, 2009 | 09:17 PM
shumax's Avatar
My impact driver didn't come with any bits, so I need to make a trip to Sears by the sounds of it. Thanks for the help!
Old May 12, 2009 | 09:42 PM
01tl4tl's Avatar
it should have 3 phillips tips and probably 2 flat bits in it, direct from sears- take the whole thing back and get an unopened unit
Old May 12, 2009 | 09:44 PM
01tl4tl's Avatar
spray everything with a rust blaster and try to tighten the screws first- a few bangs with it set right
that often bust rust bonds
then left- bang bang BANG and out comes the screw
I use a dab of caliper anti sieze grease on the screw threads on re-install
other bolts are 12 and 14 mm, and a 19 mm open wrench in case the caliper mounting bolts turn- thats the nut behind them
Old May 13, 2009 | 06:47 AM
blkaspec's Avatar
Full of water...
i used some WD40 and it worked good too...
question, is there a way to set the impact wrench to go one direction or the other? there really wasnt instructions so i just kinda turned it to the left and then hit it, but what is the proper way of using one?
Old May 13, 2009 | 10:04 AM
Tripnbeats's Avatar
YEA on the nicely tighten ones i like to get a mallet and hit the screw driver while i twist really hard after all the gunks been applied....if im not near the right tools...like last week in the middle of nowhere fl =)
Old May 13, 2009 | 10:39 AM
Tripnbeats's Avatar
http://evergreen-rentals.com/images/...r%20Impact.jpg
one of my favorite toys!
Old May 13, 2009 | 11:05 AM
01tl4tl's Avatar
WD should have been on my list of tools~ its a great rust buster
There is a collar in the middle of the impact screwdriver
It turns 1/4 turn left or right and determines the direction of force appled
Should be an arrow etched in the metal and L- R with it
Might need a magnifying glass to see it...
twist and turn or pull down and turn as needed
Old May 13, 2009 | 11:06 AM
01tl4tl's Avatar
a regular + screwdriver and hammer works if thats what you have-
the tip may be no good when you are done- but hey, thats fixin stuff in the boonies
Old May 13, 2009 | 11:27 AM
blkaspec's Avatar
Full of water...
cool, thanks. i will take a look when i get home. it must have been originally setup to turn left because it worked like a charm right out the box
datadr
Sep 12, 2015 09:12 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
asahrts
Sep 4, 2015 05:55 PM
