brake lights only work sometimes :(
Old Apr 15, 2008 | 03:59 PM
libert69's Avatar
18psi
so i get pulled over for not having brake lights and im totally confused b.c i know they have been working...i check them and all 3 are not working...i go home and check again and they are now working. last week someone told me that my brake lights were looking dim and not as bright as they should be. so for the rest of the day they have been working only when they want too. so im guessing this rules out broken bulbs and it might be an electrical problem. i have a service appt with acura on monday. any ideas? its an 04 with 74k miles
Old Apr 15, 2008 | 04:30 PM
sifuacura's Avatar
There's alot of asian in
yeah mine is doing the same, but it works all the time, but sometimes it dims.
Old Apr 15, 2008 | 04:48 PM
DanL's Avatar
May just be the brake light switch. Mine was bad (throwing a code causing the VSA light to come on) and was replaced last week on my '04 with 50K miles.
Old Apr 15, 2008 | 05:04 PM
CometVR4's Avatar
My car did the exact same. They would be dim and maybe ever 4th or 5th time I hit the brakes they would be bright and full intensity almost rear ended because of it. It was the switch also.
Old Apr 15, 2008 | 05:12 PM
evnash's Avatar
EVNS TL
brake light switch or could be a loose ground near the back of the car.
Old Apr 15, 2008 | 09:42 PM
libert69's Avatar
18psi
so im guessing this is the switch right? the brake pedal position switch in this thread
https://acurazine.com/forums/showthread.php?t=92622
so i would need to buy #6 and #8 in order to change out this piece? im going to order them from hondapartsunlimited.com...the 2 pieces are 26 bucks and it looks like i can change it myself to avoid the dealer trying to rape me
Old Apr 15, 2008 | 09:53 PM
carlos9827's Avatar
2011 BMW 335i
Dang I hope this doesn't start happening on my 05 TL.. Thats freaky cause there is no way you would know your tail lights aren't working (unless someone told you) And like CometVR4 said really increases the chances of getting rearended...
Old Apr 15, 2008 | 10:39 PM
csmeance's Avatar
Do you have a VSA (!) error on the dash? If so, it is the VSA switch and you must be careful as you have no rear brakes.
Old Apr 15, 2008 | 10:56 PM
libert69's Avatar
18psi
i did have a vsa light come on today when i unplugged the brake pedal position switch harness. it went off after i turned the car off then back on again. other then that it has never come on
Old Jan 7, 2024 | 07:56 PM
Ohun99's Avatar
6th Gear
Still having this issue in 2024 on a 08 Type S lol. Can someone confirm that the brake pedal position switch did the trick?
Old Jan 7, 2024 | 09:08 PM
Jackass's Avatar
Are you just going to spam all of the old threads that laid out the first thing to try which is to replace the switch? Yes, I will confirm that replacing the brake pedal switch fixed my dim brake light issue. It is for sure the cheapest and easiest thing to try first.
mada51589
Jan 9, 2025 04:40 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
theinsvnity
Sep 10, 2015 10:22 PM
drewdeezy03
Sep 3, 2015 08:04 PM
