Brake Brackets Help.
Old Oct 17, 2014 | 07:40 PM
iiamchili's Avatar
Hi i bought some drilled and slotted Rotors and pads from Ebay they suppose to fit my 05 TL but both front rotors and pad its a little bigger (SMH) rears fit well. The mechanic told me to to buy a bigger size brake Brackets if i want to install those Rotors. What ya think should i do ? or should i buy the bigger size brackets? witch one should i buy ?
Old Oct 17, 2014 | 07:44 PM
RedRyder's Avatar
Be a better driver
Return whatever you bought, and buy quality OE parts from a good brake manufacturer that will be spec'd to fit the same as OEM components.
Old Oct 17, 2014 | 07:47 PM
iiamchili's Avatar
Originally Posted by RedRyder
Return whatever you bought, and buy quality OE parts from a good brake manufacturer that will be spec'd correctly to fit as OEM.
Rotors are quality the are R1 concepts problem is that i already install the rear ones.
Old Oct 17, 2014 | 08:02 PM
paperboy42190's Avatar
you might have gotten the type S/6mt base rotors instead, they are 12.2" compared to the base 11.8"
Old Oct 17, 2014 | 08:09 PM
Turbonut's Avatar
Do you have an AT or MT?
Here's the rotor specs:
A/T 11.4" diameter 1.1" thickness
M/T 12.2" diameter .98" thickness
Old Oct 17, 2014 | 08:23 PM
iiamchili's Avatar
AT. so what do have to buy so they could fit ?
Old Oct 17, 2014 | 10:03 PM
Jackass's Avatar
The correct rotors for your car.
Otherwise search for the Brembo swap. You won't like what you find.
Old Oct 18, 2014 | 06:23 PM
iiamchili's Avatar
Oh ok thanks
Old Oct 18, 2014 | 07:55 PM
Just a correction, it should be 11.8" rotor for the base AT
Old Oct 22, 2014 | 04:22 PM
ExcelerateRep's Avatar
Former Sponsor
Installing quality components that are proper fitment is vital. Definitely look into our XLR8 brake packages for Acurazine:
https://acurazine.com/forums/sponsor...razine-903264/
Or if you're looking for just front rotors and pads, you can't go wrong with Stoptech rotors and street performance pads. Both are available and in stock on our website.
Brakes - Excelerate - HOA - Japanese Performance Specialist
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
