Brabus style puddle lights on the TL?
Hey I was wondering if anyone here has installed some "puddle" lights under their TL? Essentially, they just turn on when the car is unlocked and/or the doors are opened so you can see where you are stepping (hence the term puddle)...
Here's some pictures of it done on a Lexus
And here's a video on how it will work (installed on a TSX)
http://video.google.com/videoplay?do...arch&plindex=0
Let me know what you guys think
... Personally I think its a nice subtle touch but I'm sure some of you are going to think its a bit ricey
Cheers.
Cheers.
Originally Posted by CL Platano
To do it right is not an easy job, thats why I sold mine ,I was too lazy to install them
i just did an OEM Navi conversion on a 07 civic si, according to everyone it's impossible, yet it only took me 1 hour to do.
Originally Posted by ua6spec
It look nice if you dont overly do it. I have 2 on each side....I was going to put four on each side then my friend who install it say dont do it and dont waste too much money on it
Originally Posted by rbf351
it's very simple to do. you just need to tap into the dome lights since those work with the keyless entry, and when you open and close the doors
Originally Posted by ADabsolutNDN
I don't think it will be that much at all...do you have any pictures of when it was on your car, or did you never install it? Where did you get it from?
My is from Varad
Yep exactly. The only "tricky" thing would be figuring out how to attach them under the side skirts so the light source itself would be hidden but I'm reading online that a lot of people just use some double sided 3M tape (I doubt that will hold in the winter though)
You have to drill holes in your skirts, attach the pods to a tube, run the wires an average job will take about 4 hrs...
Not necessarily...the way its shown in the blue TL in the thread yeah, but there's more than one way I'm sure
Yeah the easy way is to just attach it to your car with the provided 3m tape but it will look like your car is a cow with multiple nipples
Originally Posted by csmeance
heres a pic of touge's RL with puddle lights:
Also do you know what kind of lights he used (like brand, price etc.?)
Nah I sold him a 1 led kit from Jlevi , I didnt get the 5 led kit for fear of cracking them since I drive very low.
I've been wanting to do this forever! I too have been busy and lazy priortizing other mods. I planned doing this sometime next year. There is an easy way to do it with 3m tape but I'd rather plan this out, take my time and do it right. Like that clean recessed like ua6spec's. Like it's been said don't over do it with too many modules or too bright. You might as well do an LED strip if you like that look. It should be just as the pic with the RL; sufficiently bright with focal beams and with no more than 3-4 modules. I think it's outrageous when I see some of these "kits" going for $200. There are cheaper kits out there, I'm looking out for some good stuff. If I do this sometime soon, I'll do it along with my A-Spec sill install we'll see.
I certainly agree with UA6spec, 5-6 lights is too many, reminds me of the neon tubes of the 80's... but 2 seems OK. I may go for this mod.
So set me straight, what's the "trigger" for these? when do they come on? rbf said you wire them to the overhead lights... seems easy enough...
does that mean they come on when you turn on a map light driving down the road?
Seems it would be better to wire them to the door light (ala illuminated door sills mod...), but I've see many pictures here where these seem to come on independent of any other ligth source.
These LUXART (SBL series, integrated resistor) leds seem like they'd be perfect. Surface mount, have to drill 3 small holes (2 mounting screws and one to pass the wiring through).
http://www.superbrightleds.com/mini_tubes.htm
You'd want to wire them like the illuminated door sills. EXCEPT for 1 thing; I forgot how it was grounded and everything as a trigger.....well the main thing is to make sure it turns on not just when the door opens but along with the interior lights when you press "unlock" on the remote and when you leave the car and press "lock". Having it dim/fade with the interior lights will add to the "cool" factor!
Not sure how to turn em on with both the doors and the map lights independent of each other. Not sure I want them coming on with only the map lights exclusively, that would look wierd driving down the road...
I think I'm gonna wire em to the door sills, but run a switched "double ground". That way they would come on with the doors, or come on with the switch...
Originally Posted by Kennedy
The door sills are switch grounded... The + is always hot, the - is broken when the door is closed. When the door is opened the ground closes and complete's the circuit.
this is just from looking at the schematics very quickly, so i could be wrong
looks as if you would hook it to the green/red wire(pin 5 on the homelink harness) or you can get the wire on the MICU connect I pin 4
I don't have a service manual, whick connector is MICU connect I?
I take it that's the overhead illum "door open" wire...
