B Service pricing
I just had a quote from the local soCal Acura dealer, $128. I don't know if that is all inclusive or additional taxes and service charges will be added after all is said and done. I'll find out on Saturday when I get it done.
They way I figure it, I'm looking at an expensive oil change and inspection no matter what the price.
Honda quoted $99 for their similar "minor service"
just did my B1 service today for $110 @ Acura of Glendale, CA
They took me home with an RL, man those cars are quiet!, but i hate the i drive like navi...
They did oil change, filter change, adjusted tire pressure and tire rotation.
They even told me that the Pro CATS were not properly installed and I officially have an exhaust leak
Originally Posted by zalik22
Hi,
Can someone help me out...how much did you pay for B service? I can't find any search results. Thanks!
Very good question. Just recently did a B1 service, $75 from Tustin Acura. I called Alhambra Acura, 101 Calabasas Acura, Keyes Van Nuys Acura, all at least 120. The 101 Acura is the most ridiculous, quoted me $175.
Registered but harmless
Received 1,149 Likes
Search of "B service" in the thread titles only comes up with the following, amongst others:
https://acurazine.com/forums/showthr...hlight=service
Above prices are low compared to Santa Monica Acura's $130-145 (w/o coupon...).
Code B = Cost: $164.95; includes: Oil Change, Tire Rotation, Battery Test, Road Test, Inspection of Brakes, Inspection of Tie Rod Ends, Inspection of Steering Rack
and Boots, Inspection of Drive Shaft Boots, Inspection of Brake Hoses and Lines (including ABS), Inspection of Fluid Levels and Conditions, Inspection of Exhaust
System, Inspection of Fuel lines and Connections, Inspection of Belts, Inspection of Coolant Hoses, Inspection of Lights and Controls, Inspection of Tires,
Inspection of the Inspection of Vehicle Underbody, Adjustment of the Parking Brake
^^^^^ yep 58$ at KM Acura.
oil/filter/rotation, not sure I thought the B1 has more required than that?
Originally Posted by datmrman
Oil change, filter, tire rotation, fluid check, and probably more but the first three is all you really need.
Service B @ 37500 miles
Cerritos, CA
Cerritos Acura = 128.88
Thorough inspection, can't complain. Probably won't go back for the ATF; P/S; Brake fluid flushes and filter replacements they cited at $681!!! They want $167 just to replace the A/C and air filters
Cerritos, CA
all this is designed to rip people off. Anyone can check their fluids and tire pressure themselves. I personally dont believe in rotating tires- they will wear a bit faster but you will save $100 by not doing all these scheduled rotations.
Only thing I'll do is oil/filter changes, fluid and brake checks every 4-5K miles, at 60K replace tranny fluid, flush coolant, inspect belts, at 90k replace all drivebelts, timing belt, maybe waterpump and adjust the valves. At every brake job will have the parking brakes adjusted. Replace air filter every year, new spark plugs every 100K mi.
Dont fix it if it aint broke. If something is wrong with suspension, I will know about it, there is no reason to pay someone $50 to look at it and tell me it is fine. The brake fluid can easily stay in the vehicle for 7 years regardless of mileage.
Hi,
But I'm only getting the B service...no oil change/filter/tire rotation. B service includes VISUAL inspections and belt adjustments? Better be cheaper.........!!!
HMFIC
Originally Posted by erick3
WHAT?! ACURA OF LYNNWOOD quoted me around $300.00 for B2 Service!!!...pissed
Don
mrkingstonvi
02-22-2016 01:53 PM
Zonian22
11-14-2015 01:20 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
