ATF change question
Old Feb 18, 2012 | 09:42 PM
ep3kid914's Avatar
ATF change question
is were its circled blue were u can put the oil to refill the transmission?
Old Feb 18, 2012 | 09:43 PM
SpiderX1016's Avatar
Yes, the blue circle.
Old Feb 18, 2012 | 10:22 PM
vietxquangstah's Avatar
It should say ATF on it
Old Feb 19, 2012 | 12:01 AM
swoosh's Avatar
takin care of Business in
Cant see the bolts very clearly....but i agree with VIET, it should say ATF on it...the other bolt just looks like a "ground" location....
PS the ATF bolt will be a bishhhh to break loose....i recommend breaking it loose before draining out the fluid....I was stuck once when the bolt wudnt break loose and i had 3 qts drained out....
Old Feb 19, 2012 | 12:06 PM
lusid's Avatar
FTW
If you need a video here's one I created.
Old Feb 19, 2012 | 01:40 PM
avs007's Avatar
Worst comes to worst you can refill through the dipstick tube. Tho it will fill very slowly that way.
Old Feb 19, 2012 | 01:54 PM
xander569's Avatar
My First Acura
Move that fuse box to get to it, when I did mine there was enough play in the wires that I could sit it on top of the mount it is on.
Old Feb 19, 2012 | 02:26 PM
That only applies for 07-08 models.
Old Feb 19, 2012 | 04:00 PM
quanaman's Avatar
TL-S
I jus did this last night
You unbolt the fuse box and if you get a long funnel it will be fine
FYI that bolt is going to be tight as a MOFO. I broke two extensions before I moved up to impact extensions and a breaker bar. It's ridiculous
Old Feb 19, 2012 | 05:59 PM
swoosh's Avatar
^^^ yup, as i mentioned above, its a bitch to break loose....needed a breaker bar and it always sounds like i broke something hahaha....its only the bolt breaking loose....
Old Feb 19, 2012 | 09:38 PM
ep3kid914's Avatar
thanks guys i had too use an air gun since i ended up breaking two sockets but manage to change my oil
nanos
Nov 12, 2015 08:41 PM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
mc1114
Sep 11, 2015 05:50 PM
Aleax
Sep 11, 2015 11:31 AM
