aspec body kit loose?
Old Aug 3, 2006 | 06:53 PM
ubond007's Avatar
I just noticed today that the side skirts of my kit seem awfully loose and at when you open the rear passenger door there is a gap between the skirt and the sill. is this normal or should I take it to the dealer?
Old Aug 3, 2006 | 07:08 PM
INSPIRE 32V's Avatar
Glacier Frost Mica CL-S
sounds like someone did a bad job installing that thing. double tape that SOB.
Old Aug 3, 2006 | 08:51 PM
ubond007's Avatar
I have an appointment tomorrow morning to have them fix it. The service guy was really cool and said they will double up the tape to make sure there is a strong bond.
Old Aug 3, 2006 | 10:34 PM
havokgroup's Avatar
I normally double up on the tape because the amount that comes with it is just not enough. At the shop I have a big roll of 3M double side tape just in case. We have told our Acura Rep that the amount that comes on the kit is not nearly enough.
Old Nov 21, 2008 | 09:30 PM
flip_side's Avatar
bumping this thread because I was installing the aspec sides today and the left side is a perfect fitment, but the right said has a gap between the acura door sills and the aspec side.. anyone have a solution? Why double tape? arent they all just clips?
Old Nov 21, 2008 | 10:32 PM
firstacuratl's Avatar
邵樂百
Yes ... sides are just clips so I'm not getting what everyone is talking about regarding DB tape???
Old Nov 21, 2008 | 11:00 PM
flip_side's Avatar
^thats the problem. my aspec sides have a gap on the driver side rear
Old Nov 21, 2008 | 11:42 PM
o4Komodo's Avatar
Rev High; Drive Happy
I don't have an a-spec yet..
By using double-sided tape it ensures that the under-body-spoiler stays bonded to the body of the vehicle thus eliminating any chances of gap.
Certain double sided tape are very strong, some are quite weak.
I suggest using this specific kind:
It says exterior mounting tape but you can use it for just about anything. The adhesive on this particular kind is very strong.
I have one package in my trunk... waiting for my Type-S Decklid spoiler to be painted so I can mount it [with the tape I just showed].
Old Nov 22, 2008 | 01:21 AM
flip_side's Avatar
^yeah double sided tape works for the front and rear, but the sides I don't know why theres even a gap...anyone have a solution? is it tape?
Old Nov 22, 2008 | 03:10 AM
邵樂百
Personally, I'd pull it off and make sure all clips are in place where they're supposed to be ... maybe one got pulled out of it's cradle when you installed or one of the "little clips" is worn out ... just can't see it having a gap unless something is out of place. Suppose the side skirt could be warped though???
Old Nov 22, 2008 | 11:46 AM
flip_side's Avatar
pulling it off is different from the stock skirt right, because theres no need to slide anymore it just pulls outwards correct? id have to undo the clip holding the front and rear also
I hope its not warped... it would take a lot of force to warp it right?
Old Nov 22, 2008 | 12:16 PM
邵樂百
Wink I doubt they're warped ... more likely installed wrong.
Removal should be exactly the same as the stock skirts ... pop little clips outward, then slide skirt towards rear or front, dependant on which skirt you are removing (front towards front, rear towards rear). I'm guessing one or more of your big clips isn't seated properly in it's "cradle"(slot that back of clip sits in). Just a guess though.
And yea, it'd take a lot to warp the skirts and could be easily fixed by immersing the skirt in semi-hot water for a bit, then lay flat to cool. The urethane/ABS/w/e plastic used has memory
Old Nov 22, 2008 | 12:18 PM
ladiesman217's Avatar
e92 335i
I had this same problem when I first picked up my car, one of the clips on the left side skirt was not clipped all the service technician dude was just push it in with a little force, and boom it went into place, no more gap.
Old Nov 22, 2008 | 02:50 PM
6spdtl-s's Avatar
Nismo TL yo!
I didnt use any tape on my side skirts. No fitment problems, no holding issues.
fuct
May 14, 2017 09:43 PM
ArcticDuk
Jun 29, 2016 06:57 AM
Zonian22
Nov 14, 2015 01:20 PM
Sep 4, 2015 08:03 AM
Aug 30, 2015 02:39 PM
