anyway to clean the inside of the headlight?
my driver side headlight was replaced bc of an accident but it doesnt match the otherside. the original headlight from my 04tl has some dust inside it and when the headlamp is on, it causes a shadow to appear on the inside of the lens cover and looks dirty.
is there a way to clean the inside?
takin care of Business in
Received 4,732 Likes
^^^ ![Werd](https://acurazine.com/forums/images/smilies/werd.gif)
open it up and clean it up.....while your cleaning it clear ur headlight up.....damn son that looks HAWT!!! dont really see a way you can clean it up without opening it up......wat color is ur car???
is it a different housing and new bulb on one side-?
Or somehow dirt got inside a completly sealed lens, and the back access to the bulb has a O ring on it!!!
No moisture- no dirt allowed
1 new bulb will be a different color and output-
let me try to explain better. the original headlight case (the plastic you can touch with your hand in front of the car) has dust on the inside. this causes the light from the bulb to make a blur or a shadow on the inside of the plastic housing.
the new headlight that was just replaced is clear and clean and does not cause any shadows to appear. it also seems as if the new headlight has a brighter blue color to it and the old one looks purplish. any reason for this? age?
also, there is NO mositure that occurs inside the hosuing. so i guess the seal is tight but how could dust particles get in there? the headlight was never touched and the bulbs were never replaced.
i guess ill try the compressed air trick through the fog light first b.c i dont want to risk damaging the light. but that will just move the dirt around and not clean it so i might hve to open it
pistacio
09-26-2015 09:45 AM
