Any available DIY for debadging the trunk??
Old 03-23-2010 | 07:20 AM
Sondinh's Avatar
TEAM_SONIC
I'm planning to debadge the trunk of the car, does anyone know where I can find a DIY for this? Also if I debadge the trunk will it leave and scratch marks or holes in the trunk? Thanks.
Old 03-23-2010 | 07:25 AM
Step one: Heat up some water till its warm.
Step two: pour it over the word ACURA and TL.
Step three: Peel
Step four: Use muscles and goo gone to get rid of the rest of the 3M tape.
Old 03-23-2010 | 07:30 AM
Dave88712's Avatar
Use dental floss to get behind the badges to peel them off. Them lots of goo gone and elbow greese to get the 3m tape off
Old 03-23-2010 | 07:41 AM
Dave88712's Avatar
The only one that leaves holes is the big acura A in the middle. Just remove the acura and tl badges
Old 03-23-2010 | 08:06 AM
Bayam0n's Avatar
Veni, vidi, vici
Step three: Peel
i heard peeling can damage paint. Instead, use toothfloss and "Saw" the pieces off. The 3m tape should be easier to saw off if it is warmed up with the water. you might need to polish the area when your are done.
Old 03-23-2010 | 08:22 AM
Crestwood1001's Avatar
Just use a hair dryer to warm them up and then run floss behind them, eaisyer then hot water. They will come right off then just rub the glue off and wax the area to get rid of any marks. Didnt leave a spot on my 06 WDP
Old 03-23-2010 | 08:46 AM
Izzy-Type-S's Avatar
WOT in the new ATLP V2s!
My "Acura" left an outline from dirt & road grime behind the letters but it buffed out.
Old 03-23-2010 | 01:19 PM
SpiderX1016's Avatar
I didn't debadge my TL yet but when I did my VW. I used a hairdryer to heat it up then used dental floss and finished it up with bug/tar remover to get rid of the gunk left.
I heard Goo Gone or something similar works good.
Old 03-27-2010 | 08:58 PM
Sondinh's Avatar
TEAM_SONIC
anyone input might help.
Old 03-27-2010 | 11:21 PM
AtlM5's Avatar
+1 but you'll have to clay it to get it all off
E Ace (02-19-2013)
Old 03-28-2010 | 05:05 AM
shellready's Avatar
i just got a new tl and was just wondering, why do people like to do this mod?
Old 03-28-2010 | 12:36 PM
dred87's Avatar
Cuzz it gives you a boost of 20 HP!
Old 03-28-2010 | 05:47 PM
Madchiln's Avatar
just use fishing string takes 5 mins for both acura and tl emblem. spray like wd40 or goo gone on it on and off and rub off the 3m tape takes a little bit but other then that, thats it. whatever you do don't get the bright idea of using anything sharp, i know some people who just f up there car they make no sense good luck! haha
Old 03-28-2010 | 05:50 PM
CubanLynx84's Avatar
under renovations....
I was washing my car one day in the summer and just decided to pull them off I used some fishing line and it came off with most of the adhesive. Just use a blow dryer to heat them up and use the floss or fishing line if you have it to "saw" behind it. If it is really all you'll have to do is pull from one side to the other.
Old 03-28-2010 | 06:56 PM
and shaves 50 lbs off the car.
Old 03-29-2010 | 02:00 AM
Vinsta13's Avatar
I just did mine yesterday I just got a flat head screw driver and got the right amount underneath the letters and popped em off one by one, literally took 20 seconds... The 3M on the other hand was a handful to get off.. But a little bit of elbow grease and nail polish remover helped.
Old 04-03-2010 | 06:59 AM
Sondinh's Avatar
TEAM_SONIC
Which works better? The fishing line or the dental floss?
Old 04-03-2010 | 08:33 AM
Dan1629's Avatar
Registered Member
I removed the A a couple of months ago. I used a heat gun and what looked to be a piece of thin fishing line. It was included in a kit I got from Amp'd emblems. It came off real easy no marks or scratches. The glue that was left was not a problem. The A is the only one that has guide pin holes.
Old 04-03-2010 | 09:14 AM
Bearcat94's Avatar
AZ Community Team
Looks clean & easier to clean. There is a long tradition of debadging cars.
http://en.wikipedia.org/wiki/Debadging
Either one. Doesn't matter.
http://www.youtube.com/watch?v=P41F4DT9IDs
E-016: DIY: Emblems and badges-removing and replacing
https://acurazine.com/forums/car-parts-sale-361/cl-body-kit-85353/
https://acurazine.com/forums/showthread.php?t=121019 (with scans for locations of emblems)
https://acurazine.com/forums/showthread.php?t=122040 (from 2G TL)
Old 04-03-2010 | 11:55 AM
odishaw's Avatar
^^ todays edition of "how to screw up your truck." lolll
-you might find that dental floss breaks on you, otherwise fishing line will be alot stronger. but maybe thats just cuz i have really thin dental floss for my teeth! lol
Old 04-03-2010 | 12:02 PM
218TL's Avatar
fishing line is better than dental floss, the fishing line is stronger and the dental floss tends to break. either will work, you'll just end up using more dental floss than fishing line.
Old 04-04-2010 | 12:25 AM
Matt HKD's Avatar
I used fishing line and didnt even have to heat it up, came right off. Then I used goo gone and just kept rubbing til the residue came clean. Be careful though, my friend did it on his nbp and it left swirls in his paint.
Old 04-04-2010 | 03:42 AM
Conan O'Brien's Avatar
debadged my old rsx. i live in texas and decided to do it during a string of 100 degree days. glue was already soft enough to debadge with just dental floss and my finger to rub off the remaining goo.
Old 04-04-2010 | 05:00 AM
Yeah, that's why I'm not debadging miine. I did on my black Jetta and it was left all scratched up afterwards.
Mike734
12-10-2021 01:25 PM
tsx_boy
12-13-2019 08:33 PM
baelim
05-10-2018 09:53 AM
jmaxima03
09-27-2015 10:22 AM
scionxb3003
09-22-2015 05:28 PM
Quick Reply: Any available DIY for debadging the trunk??
