Of all the people on this forum - is your headliner up or down?
Just curious. Mine has dropped again. One dealer failed fix and now my 2nd attempt has also failed. Are there people out there who have done my epoxy glue trick and it is still holding? If yes, please tell me the exact kind of glue you used, velcro used etc. I prepped each surface, I did Ron A's binder clips trick which was great, I even let it cure for 2 days, I put it on and pop, came off in under 5 minutes. I glued the center and left velcros. These are the new dealer ones that are heavier duty than the original white taped velcro. They could have made things so easy if they had repeated the snap in velcro technique used on the actual headliner - why o why did they not repeat this.
Considering the dealer again, but also may consider drilling a small hole in metal piece that velco is glued to and thread some fine picture hanging wire through it - or even zip ties at this point.
Any successful - long term glue solutions and brands would be appreciated at this point.
RonA posted a perfect solution a while ago. I detached all three velcros from the headliner, put those lousy sticky thing back on the metal side with some epoxy glue (the kind that comes in two syringes) and put pieces of duck tape on them overnight before I velcroed back the headliner next day. It's been over one week and it stays attached. Given it only took me 10 min and $3, you shouldn't rely on your dealer to get this done. Good luck!
The glue is plenty strong - like yours - the two syringe epoxy stuff is great - but hopefully your white velcro tape will hold - mine ripped apart like I said in two weeks - I was bummed.
...still waiting for mine to drop (3000 build model).........anyways I have some experience with epoxy..........first the white strip that you are gluing see if you can get a better quality one (one that isn't made of 2 pieces like that)..........second make sure the epoxy is for metal and cloth...............and the best trick I can suggest is put some tiny pinprick holes into the white strip...big enough to let some glue go in and a little to the other side (but not so much to affect the function of the strip).......having the glue go through the strip at places will hold better than just having it on the back side.\
good luck
good luck
Tbone2004 WAS FIRST There was much discussion about this, but he was the first to actually epoxy the piece back on, as far as I can tell. See this thread http://www.acura-tl.com/forums/showthread.php?t=79379
Mine is still holding, but I don't open my sunroof much. I think that contributes to the demise of the velcro strips.
I thought of another thing to hold the velcro on when you use the epoxy - a clothespin
What can be done? Acura's fix was useless. Gotta take better advantage of the clip holding thing on the headliner.
Originally Posted by SmokeTL
Mine was down last week, I took it in to get an oil change and they fixed it then....it was thursday, so far so good. However, I haven't had the sunroof open at highway speeds.....which is the true test.
mines been hanging since the first day i got my car. I've went to the dealer twice already and i stopped going because the service manager said an original fix is due from acura. Welp its been over a month. Still no call. I'm debating whether i should fix it myself. Where do you guys go to buy this epoxy glue stuff? pepboys?
I'm starting to kinda regret buying this car. After riding in my girls 325i, i kinda wish i got that instead. someone give me some words of enouragement.
I used the double tube epoxy. Sanded all surfaces, added 2 extra contact points of velcro and let cure overnight. It lasted about a month and now the center one is down again. I think the velcro used on like the EZ pass in NY and NJ would be the best but I can't find any. Any recos on where to get that stuff?? Doug
Originally Posted by TBone2004
Thanks Ron. Ron, there must be a better way to fix these. not much room for nut and bolt. I need the bottom velcro piece to have like tabs sticking up to feed through a hole in the top metal support piece. I have been envisioning like a cotter-pin approach.
You could make a clip to which you would attach the velcro, maybe with a rivet and washer, and then slide that over the spring steel bar, instead of epoxying the piece to the bar. You could just take a piece of metal (the stuff they sell in Lowe's and Home Depot to reinforce studs and rafters, or something similar, might work.) Then, rivet the velcro to it, bend it back 180 degrees to form a clip type thingey, and push that on the metal bar.
That is the only thing I can think of, but it probably won't work because the rivet would make it too thick and it wouldn't hold the headliner close to the window frame, so maybe it is not a great idea.
I really don't have a solution, but Acura has to come up with something. This is getting ridiculous!!!
They need to reinstall a new metal braket (this spring steel stuff) with a similar notch for holding the velcro - like the bottom has. Where does this metal attach? Easily removed?
Fat chance of this probably.
The metal strip the velcro fastens to is spring steel. Can you drill spring steel? Even if you could, you would have to remove the whole headliner to get access to the strip.
Originally Posted by PeterUbers
Mine hasn't dropped... but MAN!! does it creak and rattle over every type of road surface...
Originally Posted by Bobzmcishl
Ditto - After almost 3k miles, I am hearing my first rattles from around the sun roof area, but no drooping headliner as yet.
Ron,
Will a magnet stick to that steel? Found a website that can custom make magnets. If they were to make me one in the shape of the bottom piece velcro - I could slide it in the existing clip on the headliner and let it stick magnetically to the steel piece...these are supposedly the really really strong magnets, not your typical fridge magnet.
It looks like the springy thingy is part of the moonroof frame. It looks like there might be a rivet attaching it. I don't think you can weld spring steel, can you?
If you open the moon roof and look in the channel, at the rear there is a round indentation about 3/16", and I think that what holds the bar in, so it is not easily removed.
By the way, I've never heard of this problem before. Are you sure you are describing it correctly? What did you do to make this happen?*
*Things a service manager might say
Ron,
Sounds like this might be a plan if you could get a magnet small enough to fit in the headliner clip yet powerful enough to stay attached to the bar.
Too funny. Yes, I expect to be accused of doing chin-ups at traffic lights or something!
That is why I am trying anything than to have to go back there again....noooooooooo...not the service department!!!
for those who have never had the problem - you are saying your liner is snug up against the sunshade - no gap at all? :sqnteek:
Cause for a while I did not think I had the prob, but when I looked closer I saw the center had actually popped loose.
Open you sunroof all the way and look in...I would be VERY surprised if it did not come undone.
Mine does not have a big gap at all. It changes with the temperature. Sometimes it pulls up other times it hangs low - Just like George said on Seinfeld once. The water was cold...
A magnet will stick to the spring bar.
Been talking with the magnet people. I am going to fit a piece of metal in the clip holder - like 1" x 1" (same size as current velcro) then buy one of their super strong magnets - they have all sizes, I am going with the 3/4" x 3/4 " x 3/8" - Nickel Plated, Grade N38.
Stick the magnet to the metal piece in clips and stick other side to roof. (there is a pole on both ends)
- I think it is $3 bucks. What the hell right? I have spent more than that on losing lottery tickets.
If it works and looks to be a good hold, I will do all 3 across the front. Worst case scenario I can hang a picture of my TL on the fridge with the magnets!
I think part of the problem is that the center is higher than the outer contact points. If you were to "build up or fill in the space a bit" I think we'd have a better chance of whatever holding but you might be left with a very slight gap say a 1/4 inch which I think is acceptable. I havn't really taken a really good look in there since I epoxied everything. Now that the center is down again I'll take another look. My outer 2 points are holding so the center is not very bad at all right now and I do alot of driving with the roof open.
TBone is right. I didn't even know that it dropped until I read the threads about this. Only way to confirm it is to open up the sunroof and look inside. When two of three velcros got detached, I only saw about 1/4-1/8" gap!
dougpt10- the center is higher because the metal bar is springy. If you pull it down, it will flex and bow downward, when you release it, it will flex back up. I guess there is a reason for designing it this way, maybe to allow for the air pressure when the moonroof is open. When all 3 pieces of velcro are attached to the springy bar, the headliner edge will be parallel to the moonroof opening and look better.
novice-mine was the same way. I never noticed it until I read about it here, and then I opened the moonroof and found the center and passenger side velcro had come loose. Some people say theirs droops so much it almost touches their heads, but most only get that little space because the headliner is made of firm material.
TLDude876
12-28-2016 03:18 PM
handsom-hustla
11-13-2015 05:04 PM
09-17-2015 09:01 PM
