Air Noise
Air Noise
hey all experts...
This air noise is bothering me since I've got the TL... when I put the car on hwy and outside air noise is too much... well I didnt except this from ACURA. My accord has lots of noises but that didnt bother me but now TL is luxury sedan and it bothers me.
In my experience, air noise is really common in Acuras...I had a lot of it in my CL-a and a fair amount of it in my TL too....nothing you can do about it...not really a big deal either, right?
Re: Air Noise
Acura says:
EXTERIOR (SIDEVIEW) MIRRORS
Mirror housing needs to be small and aerodynamic to reduce turbulence-without compromising mirror area. To reduce the housing size engineers devised a way to hold the mirror element from behind instead of at the sides, and carefully controlled the gap between the mirror element and housing to further reduce turbulence. Blue-tinted mirrors also reduce eyestrain in bright conditions.
Engineers also measured the airflow through the channel between the A-pillar and the mirror. By designing this channel in an expanding V-shape, the air actually decelerates (rather than accelerates) as it moves across the glass. This helps keep the air from tumbling across the side glass, reducing high- and mid-frequency noise.
Engineers also positioned the mirrors forward, away from the window glass, to further reduce wind noise while increasing the driver's side view. A reverse tilt function automatically tilts either the left or right mirror down when the TL transmission is shifted into Reverse. This is a driver-selectable function that may be turned on or off as desired.
Whatever Acura said, IMO, I think their design has failed. The strong wind blow or turbulence really make some noise. I'm pretty sure all liners, insulation, or deafening are tight and fixed. My stupid dealer agrees Acura's vehicles have this problems.
P.S. Next time, you may pay attention to your driver side window after the rainy days. After driving in high speed, the turbulence would leave some water lines or stains over your windows from A-pillar to B-pillar, and those lines/stains are just right around your ear's level.
I agree, there is more wind noise than should be. I also believe its the mirrors. There are too much pieces that make it a side mirror. Take a look at some other mirrors on say BMWs, and can see a more molded in look
I have been on the freeway at about 70 to 80 and have not heard a lot of noise. In fact, I do not turn up my stereo to compensate like most other cars. Maybe I am spoiled as I have only had domestics previously.... and they get a lot louder.
Well My friend has 03 accord and I think his accord got better ride (to me the ride is better, maybe accord has 16 inch rims and better tires)and less noise.... wtf? I'm going to drive his car again to see if it got air noise or not...
Only time I have experienced any excessive wind noise was when I either (1) forgot to close the sunroof or (2) Have a Panthers flag attached to my window (creates a small gap). Otherwise this car is as quiet as my Mercedes and BMW have been. I honestly don't know what you are talking about regarding noise. Have you checked for proper seals? Have you driven dealer demos to verify that others seem as noisy as yours does?
a car with 16 inch rims and meater tires will ride smoother. The sportier rims and tires on the TL will not ride as well, but will out perform. Don't buy a more performance oriented sedan if you dont want the feel of it.
**** then i gotta visit the dealer asap.......... damn it.....
for real guys, I tried what joganjani did, turning off the stereo but i do hear it from driver side.... window rubber seems to be fine but who knows... dealer is the best place to check it out with their demo.
It seems like after I put the felt in for tinted windows, I can hear more wind noise from driver's side. Maybe it's my imagination. Perhaps, they didn't roll the windows all the way up. I want to wait 3 days before open and closing the windows.
Also, I think they actually cut the inner wipers to put the felt in. I have to check it out again tomorrow during day time. Is this normal?
This tinted windows is causing me so much more grief. If I've known, I would rather live without the tint.
Originally posted by zexi
This car is very quiet, you must have somthing wrong with your windows. To me one of the quietest cars I have ever ridden in.
rcs86
08-02-2016 06:52 PM
dainmezron
10-16-2015 06:56 PM
joflewbyu2
10-08-2015 11:16 AM
4drviper
09-23-2015 09:00 PM
