Air filter
Registered Member
I am going to assume you are asking about the engine air filter. The answer is no if it is classed as an OEM replacement part. I have been using the Purolator A25585 filter in both of my 3G TL's and it works fine. Incidentally, the stock "Honda" filter for the TL is a good unit, though somewhat restrictive. It is a dual plain filter with an oil-wetted bottom section and a dry element top section.
WDP Director of R & D
Pretty much the only way an air filter would void a warranty would be if th engine was able to ingest particles resulting in "engine damage". If you are remotely unsure or concerned with this issue on any given air filter - why purchase it...
Bottom line, somewhere within the air filters documentation it should state: "meets or exceeds manufacturers requirements" etc..
Originally Posted by blueninja36695
I just want to make sure and don't give a dealer an excuse to void my warranty.
Registered Member
Originally Posted by avs007
The only time I've heard of the dealers hassling you, is if you have a K&N filter, and you over-oiled it, causing the MAF to get caked with oil. But in that case, they only voided the warranty on the MAF itself when it needed to get replaced because it was caked in oil.
Originally Posted by SouthernBoy
The '04 and '05 TL's do not have a MAF. Can't speak for rest of the 3G years.
Registered Member
Yeah sorry, I always interchange MAF and MAP sensors when I talk. They serve the same purpose. The 3G TL has a MAP sensor, located in the throttle body. I've heard of dealers voiding the warranty on the MAP sensor if it fails due to it getting gummed up with filter oil.
Our TL's, of course, utilize speed density methodology.
rcs86
08-02-2016 06:52 PM
