5AT Premature down shifts problem?
Old Jun 22, 2005 | 11:32 PM
jhan1102's Avatar
Regarding 2005 TL Navi 5AT:
Has anyone experienced strange down shifting problem when stepping on the gas not in the SS mode?
When I知 in the 4th gear and step on the gas, it down shifts prematurely or too soon, and short. Then it feels like I知 loosing power.
Old Jun 22, 2005 | 11:58 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
Do you mean "up-shifts?" Downshifting would be desireable and would give you more power.
Old Jun 23, 2005 | 12:08 AM
jhan1102's Avatar
downshifting forsure.
It downshift prematurely at low rpm.
Old Jun 23, 2005 | 12:23 AM
bluenoise's Avatar
So it shifts from 5 to 4, for example, when you try to accelerate?
Old Jun 23, 2005 | 02:40 AM
jhan1102's Avatar
I went out and drove around.
This is what happens:
I'm on the 4th, press the gas, it downshifts to 3rd, before the rpm picks up, it upshifts back to 4th. this happens very quick.
Old Jun 23, 2005 | 03:16 AM
JetJock's Avatar
Push harder on the gas. I think the transmission is confused and thinks you want a lower gear, then since you don't have your foot on the gas hard enough, it shifts back to 4th gear. If you want to hold the downshift, you've got to put your foot in it.
Old Jun 23, 2005 | 10:18 AM
jhan1102's Avatar
No no no... I pressed pedal to the metal.
Am I the only one with this problem?
Old Jun 23, 2005 | 10:40 AM
crazymjb's Avatar
Definatly worth a trip the dealer. It seems that that would be preferable. The good news is that is probably a software error, if its not supposed to be there, so its something they can easily fix, with no taking stuff apart.
Old Jun 23, 2005 | 01:04 PM
bluenoise's Avatar
Originally Posted by jhan1102
...before the rpm picks up, it upshifts back to 4th. this happens very quick.
So, it would seem this is a premature upshift problem, not downshift. It downshifts just fine but then upshifts at too low an RPM for what you're trying to do. I'd have the dealer look at it.
Old Jun 23, 2005 | 01:22 PM
jhan1102's Avatar
yeah... its upshift prob.
It felt like it downshifted again.
Thanks for the help guys. I'll post back again.
Old Jun 23, 2005 | 01:46 PM
ravingstylez's Avatar
no no i have the same problem .... it actually downshifts to get the rpms up then it upshifts ....like it should only while the rpms go up the car does not move
Old Jun 23, 2005 | 01:57 PM
snapfisher's Avatar
How fast are you travelling when this happens?
It supposed to downship when you jam on the gas. It also always tries to upshift whenever practical for better gas mileage.
I want to see if my new '05 does this.
Old Jun 23, 2005 | 09:57 PM
jhan1102's Avatar
So I am not alone.
This happens around 35-45 mph zone.
Old Jun 24, 2005 | 01:50 PM
TheTriads's Avatar
normal. You hit the gas to the metal while at 4th, it'll shift to 3rd trying to accelerate at a higher RPM. Suppose you let go the gas pedal right after than, the computer should let go the RPM and shift into 4th. Assuming you keep your foot on the gas pedal still, it should keep it at 3rd and try to hit that high rpm then shifts for you.
Old Jun 24, 2005 | 07:40 PM
jhan1102's Avatar
Abnormal bro.
"I'm on the 4th, press the gas, it downshifts to 3rd, before the rpm picks up, it upshifts back to 4th. this happens very quick."
I never let the gas pedal go.
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
Frathora
Sep 28, 2015 11:29 PM
Dunnik
Sep 14, 2015 02:56 AM
phillyguerrilla
Sep 11, 2015 06:39 PM
HeloDown
Sep 8, 2015 06:51 PM
