3G TL owners who have done the 6MT/Type-s brembo swap
Old 05-10-2011, 01:54 PM
bforbrian's Avatar
Interested in doing the brembo conversion, but would like a concrete answer as to whether the following list of parts is the exhaustive coverage of ALL parts needed? Or will I need additional parts?
I have a 2005 TL. Are the sensor assemblies required as well?
And finally, which of the following DON'T I need?
45018-SEP-A60 CALIPER SUB-ASSY., R. FR. -calipers with pins and spring
45019-SEP-A51 CALIPER SUB-ASSY., L. FR. -calipers with pins and spring
45022-SEP-A60 PAD SET, FR.- Brembo OEM pads
51210-SEP-A01 KNUCKLE, R. FR.
51215-SEP-A01 KNUCKLE, L. FR.
57450-SEP-A01 SENSOR ASSY., R. FR. -wheel speed sensor (if req'd)
57455-SEP-A01 SENSOR ASSY., L. FR. -wheel speed sensor (if req'd)
45251-SEP-A51 DISK, FR. BRAKE (17 in.) x2 -rotors,Brembo blanks
45255-SEP-A50 SPLASH GUARD, R. FR. -backing plate
45256-SEP-A50 SPLASH GUARD, L. FR. -backing plate
90651-SEP-A50 CLIP, R. CALIPER x2 -shim between bolt,knuckle and caliper
90656-SEP-A50 CLIP, L. CALIPER x2 -shim between bolt,knuckle and caliper
90107-SEP-A50 BOLT, CALIPER MOUNT x4-caliper to knuckle bolts
01464-SEP-A50 HOSE SET, R. FR. BRAKE- flex hose with brakets and clips
01465-SEP-A50 HOSE SET, L. FR. BRAKE- flex hose with brackets and clips
46335-SEP-A50 PIPE G, R. BRAKE - flex hose to caliper steel line
PIPE G, L. BRAKE - flex hose to caliper steel line
Much thanks AZ.
Old 05-10-2011, 02:01 PM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
B - is that same list that's in the 3G garage Brembo Swap post?
Edit - nm. Looks the same plus maybe a few parts.
Old 05-10-2011, 02:03 PM
bforbrian's Avatar
B-
I checked the 3G garage first under brakes but didn't see anything under brembo swap.
But chances are that this list pops up in brake threads every now and then but I wanted a firm answer as to whether this is the inclusive list, without any other parts needed...
Old 05-10-2011, 11:10 PM
dred87's Avatar
bump! I wanna know tooo...
Old 05-11-2011, 06:51 AM
Fearless DIY Guy
DeathMetal's Avatar
IIRC, doesn't the OE brake swap run just as much, if not more, than an aftermarket kit?
Old 07-08-2011, 07:57 AM
2011 ZCP E92 M3!!
dave_ramkumar's Avatar
can the same spindles be used?
Old 07-08-2011, 08:52 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
anyone ever tried re-man brembo calipers from autozone? quite a bit cheaper, should be good still.
Old 07-08-2011, 09:09 AM
bforbrian's Avatar
Spindles only from 04-08 MANUAL TL's can be used, and also 07-08 type-s.
Old 07-08-2011, 09:10 AM
bforbrian's Avatar
Yes, but those who usually do the swap obtain the parts used for a lot cheaper, as was the case for me. It was less than half the price for a Rotora or a Stoptech.
TypeS860
09-03-2021 06:42 PM
lanechanger
10-13-2015 10:56 AM
xsilverhawkx
09-28-2015 06:51 PM
jmaxima03
09-27-2015 10:22 AM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: 3G TL owners who have done the 6MT/Type-s brembo swap
