The 3G Ramblings & General Discussion Thread (V)
Old 07-14-2016, 10:36 AM
  #4081
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
You just jelly.
Hatter.
cu2wagon is offline
  #4082
rockstar143's Avatar
Received 19,986 Likes on 14,496 Posts
I play it sometimes. It's pretty fun.
rockstar143 is offline
Old 07-14-2016, 10:37 AM
  #4083
nevermind, I misread that. i thought you said my dick not pokemon go.
Old 07-14-2016, 10:38 AM
  #4084
cu2wagon's Avatar
The hell is pokeman go? Like at the truckstop?
cu2wagon is offline
TacoBello (07-14-2016)
Old 07-14-2016, 10:43 AM
  #4085
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Lot lizards at the truck stop
TacoBello is offline
Old 07-14-2016, 10:44 AM
  #4086
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
That's a brilliant idea for an app!
maharajamd is offline
Old 07-14-2016, 10:47 AM
  #4087
they already have that...it's called grndr
Old 07-14-2016, 10:52 AM
  #4088
Received 8,694 Likes on 6,708 Posts
thoiboi is online now
Old 07-14-2016, 10:58 AM
  #4089
Yumcha's Avatar
Received 22,807 Likes on 13,987 Posts
Morning, folks.
Yumcha is online now
Old 07-14-2016, 11:02 AM
  #4090
why yes, henri...it is!
Yumcha (07-14-2016)
Old 07-14-2016, 11:05 AM
  #4091
lunch time...
got a salad
Old 07-14-2016, 11:07 AM
  #4092
Yumcha's Avatar
Will try to work out for the first time this week.
Stupid stinking cold...
Old 07-14-2016, 11:09 AM
  #4093
cu2wagon's Avatar
Some times you just wanna mouth-poke a toothless meth head in a dirty white skirt while your rig fills up with diesel. Knowwahttamean.
The better app would be like grinder but you could also specify that they bring you a carton of Kools, some Pemmican, and a 72 oz diet Dr. Pepper when they head out to give your Johnson Rod a gummer polishing.
cu2wagon is offline
Old 07-14-2016, 11:12 AM
  #4094
maharajamd's Avatar
gummer polishing
Old 07-14-2016, 11:21 AM
  #4095
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Disneyland season ticket holder over hurrrrr....
Johnny and Bryan we can meat up at Disneyland now, anytime you'd like.
Flipster23 is offline
Old 07-14-2016, 11:23 AM
  #4096
Flipster23's Avatar
I didn't get to pay that SoCal hook up price..... But ehhhh, I'll live.
Old 07-14-2016, 11:25 AM
  #4097
TacoBello's Avatar
Did some parts pricing... Clutch parts are cheaper than I expected.
LuK clutch kit - 223.66
LuK double mass flywheel - 265.08
LuK M.C. - 41.15
LuK S.C. - 75.06
all prices are in Canadian dollars... Just have to add shipping. Revamp the entire clutch system got $605 in parts. I can't imagine labour on replacing the clutch and flywheel would be more than $600. I can do the M.C. and S.C. Myself... Hmmmm...
The following 2 users liked this post by TacoBello:
hannamand (07-14-2016), justnspace (07-14-2016)
Old 07-14-2016, 11:36 AM
  #4098
maharajamd's Avatar
What exactly is it doing? Just hard to get into gear? Does the clutch slip or make any noise?
$20 says it's the mc/sc not the clutch.
Old 07-14-2016, 11:40 AM
  #4099
In the spirit of poke a man.. changes are in order
Originally Posted by cu2wagon
Some times you just wanna mouth-poke a toothless meth head in a dirty white wifebeater while your rig fills up with diesel. Knowwahttamean.
Old 07-14-2016, 11:41 AM
  #4100
Cum on over! Hit me up whenever you're in town.
LuK M.C. - 41.15
LuK S.C. - 75.06
I'd do MC/SC before the clutch
  #4101
cu2wagon's Avatar
A mouth hole is a mouth hole, ammirite?
cu2wagon is offline
Old 07-14-2016, 11:46 AM
  #4102
hoes gonna be hoes
Old 07-14-2016, 11:56 AM
  #4103
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
fun size
Majofo is offline
Old 07-14-2016, 11:58 AM
  #4104
TacoBello's Avatar
You're right- clutch doesn't make noise.
the pedal itself I find has a bit of a... I don't know how to describe it... Bumpy feel when released. It's not operating smoothly and makes a bit of noise. I figure that's attributed to one of the cylinders.
the other (and main) issue is once in awhile, generally when shifting above 5500rpm, but sometimes even when reversing out of the garage, the pedal gets this extremely firm feel. When it happens and I am in gear, if I push the clutch down, I can't shift out of the gear. It's like it gets stuck. The clutch pedal also doesn't want to rebound as it should. I'm either forced to shut the car off and get it out of gear, or stall and get it out of gear. I pump the pedal a couple times and it works normally again, as it should.
if it happens when in neutral and trying to go into gear, I have to pump the pedal a couple times to get it to work again.
Both of these sound like cylinder issues. However, I'm worried that i caused excessive damage to the pressure plate and/or flywheel. It's not always apparent that the clutch is acting up while driving, so if the clutch stays partially engaged, it is likely wearing big time.
There have been threads on this issue on AZ, and I believe crabman even had it too. Most people replied their clutch and the problem went away. I'm not sure if that is because they also replaced the SC, or there are two slightly different issues causing similar problems. For some, the clutch replacement worked. for some the SC replacement worked. Not sure. No one has ever come back to say what the problem and ultimate fix was.
Old 07-14-2016, 12:03 PM
  #4105
cu2wagon's Avatar
Sounds like one of the cylinders.
All the masters I've had fail have had dripping fluid coming through the shaft seal into the footwell right at the firewall.
I *think* I replaced a slave cylinder but I don't remember the symptoms. Probably was the fact that the master *wasn't* leaking.
cu2wagon is offline
Old 07-14-2016, 12:05 PM
  #4106
cu2wagon's Avatar
Clutch usually fails with slippage so you could get going at a moderate pace (25mph Canadian equivalent) or so, and then shift to third. Floor the gas and if RPMs go up quickly without a real speed increase, that's the clutch.
cu2wagon is offline
  #4107
cu2wagon's Avatar
Fix the master cylinder, slave cylinder, and clutch all the same way: Jack the car up, apply a liberal spraying of Plastidip and let dry.
cu2wagon is offline
Old 07-14-2016, 12:24 PM
  #4108
TacoBello's Avatar
see, this is what I'm talking about!
Clear, concise methodology on fixing an issue. Cul0, I'm glad you know your shit. I'll try this as soon as I get home!
Old 07-14-2016, 12:32 PM
  #4109
Check the rubber grommet that goes over the clutch fork into the transmission case, Adam. I missed it for years but mine was broken which allowed water/humidity to get in there and actually rusted the inside portion of the clutch fork...caused a creak in the engine bay and also a weird not smooth pedal feel. I replaced it and used a syringe with honda high temp grease and a mirror to lube up in there...was smooth as the skin between my toes by the time I was done.
Old 07-14-2016, 12:34 PM
  #4110
Jeff
Oh Sickest TL's Avatar
what y'all saying today
Oh Sickest TL is offline
Old 07-14-2016, 12:38 PM
  #4111
cu2wagon's Avatar
...bullshit
and party and bullshit...
cu2wagon is offline
Old 07-14-2016, 12:43 PM
  #4112
Jeff
Put another coat of polish and wax on the whip yesterday, now I need to buy some QD. Do y'all use the meguairs stuff or just use a wheel rag and wheel cleaner to touch up the areas
Old 07-14-2016, 12:45 PM
  #4113
BreezyTL's Avatar
Received 1,018 Likes on 761 Posts
make sure your flux capacitor is tight too. That causes all sorts of issues if she's loose.
BreezyTL is offline
Old 07-14-2016, 12:46 PM
  #4114
BreezyTL's Avatar
A good loogy, and some sand paper to dry it up.
BreezyTL is offline
Old 07-14-2016, 12:49 PM
  #4115
Jeff
thanks! Just what I was wondering. ill take some 40 grit to it
Old 07-14-2016, 12:50 PM
  #4116
hannamand's Avatar
LuK M.C. - 41.15
LuK S.C. - 75.06
JC Whitney also has it for $263... says it will only fit the "Base" model, not the Type-S... I thought the 2004 didn't have a Type-S option?
hannamand is offline
Old 07-14-2016, 12:53 PM
  #4117
Jeff
type s was 07 and 08. cmon old man lol
Old 07-14-2016, 12:55 PM
  #4118
BreezyTL's Avatar
I have always like the Meguir's QD with a microfiber. Does the job!
BreezyTL is offline
Oh Sickest TL (07-14-2016)
Old 07-14-2016, 01:02 PM
  #4119
BreezyTL's Avatar
Piecing together some suspension parts. What should I go with here.
Truhart Rear Upper Camber Arms for $140
or
Megan Racing Rear Upper Camber Arms for $112
or
SPC Rear Upper Camber Arms for $85/each (I think)
BreezyTL is offline
Old 07-14-2016, 01:04 PM
  #4120
Jeff
why not get the skunk 2 for the front?
EDIT: I see you mean the rear! SPC hands down brother, thats what I have on my car
any of you guys fucking with that Future ET mixtape?? FIRE!
Quick Reply: The 3G Ramblings & General Discussion Thread (V)
