-32 Below Zero today! in Wisconsin
Old 01-21-2011, 07:28 AM
alpha2beta's Avatar
My poor TL I wish I had a block-heater for it today, but it does help I am using all synthetic fluids in the car.
Is there any way I can add a block heater to my car?
Old 01-21-2011, 07:29 AM
LoveMyTL-S's Avatar
Brrrrrrrrrrrrrr
Old 01-21-2011, 07:42 AM
Keep Right Except to Pass
1995hoo's Avatar
Too bad the game Sunday isn't in Green Bay, if it's that cold.
Old 01-21-2011, 07:47 AM
Stepien20's Avatar
Aye another person from Wisconsin! As for the cold :thumbsdow:thumbsdow
Old 01-21-2011, 07:54 AM
US Navy Seabees
Ruby's Avatar
are you asking how to install an engine block heater? Or are you asking if it is possible to equip an Acura TL with such a device? Please elaborate or else we can't help you.
Old 01-21-2011, 08:02 AM
LoveMyTL-S's Avatar
I think he asking if it's possible..........
Old 01-21-2011, 08:10 AM
VQPower37's Avatar
to install a block heater an electric outlet needs to be close by correct?
Old 01-21-2011, 08:14 AM
LoveMyTL-S's Avatar
You have to plug it in somewhere
Old 01-21-2011, 08:20 AM
ggesq's Avatar
Received 2,182 Likes on 1,210 Posts
here's what i found from searching "engine block heater"
https://acurazine.com/forums/showpos...06&postcount=9
https://acurazine.com/forums/showthr...e+block+heater
The 3G Service Department (sticky on main 3GTL page) is a great resource. Try it out.
Old 01-21-2011, 08:28 AM
08 MDX, 04 TL (sold)
jhumbo's Avatar
I thought -4 in Chicago was bad. Did it have any trouble starting up or sound rough after startup?
GO BEARS!
Old 01-21-2011, 08:39 AM
Turbonut's Avatar
I get cold when it's 20 degrees, let alone -32!!!!!
That block heater into the drain plug pretty good idea. I hadn't seen one before, only replacement of core plugs.
Jesstzn's Avatar
Yeep ... Most cars up here get what they used to call a "Winter Package" which was a block heater. Mine came with one and so did My Cobalt.
Old 01-21-2011, 09:04 AM
Land of 10,000 lakes
nate_0022's Avatar
Taken 5 minutes ago in Cloquet, MN
Old 01-21-2011, 09:05 AM
Comptechtl2367's Avatar
Two more people from WI! Go Packers!!!
Anyway you can get a heater that you splice into your upper rad hose that heats your coolant. I had one on my civic when i lived in WY for college. Its cheaper and alot easier then a block heater but you will need a long ass cord to plug it in.
Old 01-21-2011, 09:29 AM
alpha2beta's Avatar
Thanks ggesq. I guess I should have looked more before posting. And I think the CEL on these cars don't go any lower than -22 cause thats the lowest I have seen yet in my car and it was way colder than that today.
My car is also from Texas so no winter package for me.
Old 01-21-2011, 09:40 AM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Old 01-21-2011, 09:41 AM
CLtotheTL32's Avatar
Received 9,502 Likes on 6,173 Posts
Holy shit
That's wayyyyyyyyy too cold. I freak out once it gets below 60
Old 01-21-2011, 10:01 AM
devin1tl's Avatar
Thank god for remote starters and heated seats
Old 01-21-2011, 10:08 AM
jisleyjr's Avatar
Gotta love winter! You got me beat it was only -27 here.
jhumbo: No car likes to be started when it is this cold. But i've had only minor issues starting at this cold. The engine will crank a little slower and will fire up, stumble and then die. Cranking again it fires up right away and idles fine. The MID and radio display are in slow motion though, kind of entertaining to watch as you change screens. The car makes extra creaking noises at that temp.
My car is parked in a garage at home most of the time and that was 20 above today, and i have heated underground parking at work so i am lucky there.
Old 01-21-2011, 10:09 AM
myron's Avatar
it's a must on all cars up here. I got it on my 3g and my 2g. If I have to plug it in at home I run an extension cord outside (if I can't park in the garage). And at work, I got an electrical outlet in front of my parking stall. It gets to -40 Celsius or even colder with wind chill, so like I said, it's a must to have an engine block heater.
Old 01-21-2011, 10:28 AM
sddale's Avatar
I'm in WI but I haven't seen lower than -11. Thankfully the garage is heated.
Even though I'm in WI I have to say BEAR DOWN!
Old 01-21-2011, 10:32 AM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Originally Posted by lovemytl-s
brrrrrrrrrrrrrr
+1.
Old 01-21-2011, 10:54 AM
Osus14's Avatar
wow, that's cold. Just thinking about it gives me the shivers. It is like 22 degrees here and the sun is out. I'm glad i'm not in wisconson
Old 01-21-2011, 11:19 AM
BAM1369's Avatar
-25 in MN today. The good ol TL started up like a pro. Im scared to bump my type r's in my blazer though.
LasVegasTL's Avatar
Whoa that's cold. I don't even think it was that cold when I went to Dutch Harbor 2 years ago.
Old 01-21-2011, 11:44 AM
Former Whiner
Souljah's Avatar
I was complaining at 10ish
Old 01-21-2011, 12:46 PM
nfnsquared's Avatar
Received 1,794 Likes on 1,347 Posts
You can, but you really don't need it, especially if you're running 5w20 syn oil.
If you want to go the heating route, I'd go with an oil pan heater or an in-line coolant heater (as posted earlier) rather than a block heater.
Old 01-21-2011, 01:09 PM
1995hoo's Avatar
Coldest reading I've seen on the MID was -8°F at Mont-Tremblant, although the wind chill that day was around -30°C. I'd love to see an MID reading from a place like Minot, ND, first thing in the morning. I wonder how low the MID can display (I've never looked in the manual to see if it says). I know it tops out at 111°F because mine has hit that reading several times, but I have no idea how low it goes.
Speaking of cold weather, I like to drive my TL without a coat or jacket whenever possible, even when it's super-cold, because the seat heater feels better that way. Anyone else do the same?
Old 01-21-2011, 01:20 PM
OCD
Roger555's Avatar
Are those temp normal for your winters? You know were right on cusp of an 80,000 year iceage cycle its not gonna get any better that's for sure
Old 01-21-2011, 01:22 PM
Slythslyr
spcslyusarmy's Avatar
chillin at 52 here...when i was in korea it was about -25 for 2 weeks..that sucked
Old 01-21-2011, 01:38 PM
nfnsquared's Avatar
Coldest I've seen on the MID in my 5 winters up here is -18F. It's been colder, but I was sound asleep during those temps
x2. Nice to have a remote start and a pre-heated car. Jacket comes off before I get in my nice warm car...
Originally Posted by Roger555
... You know were right on cusp of an 80,000 year iceage cycle its not gonna get any better that's for sure
Eh? What happened to Al Gore's Global Warming? Damn, guess I'll have to vent another 10lb jug of R-12
Old 01-21-2011, 01:42 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
My TL moaned and groaned this morning after starting
Old 01-21-2011, 02:06 PM
blktl04's Avatar
my tl grumbled and moaned..... but fired right up. -21 when i went to start it.
Old 01-21-2011, 06:10 PM
I'm Craig
cjTL's Avatar
Bleck. It's burning up down here in Indy. We're at about 2 degrees right now. -2 this morning.
Aside from excess interior rattles and occasional power steering moaning, our TLs do great in subzero weather.
Old 01-21-2011, 06:33 PM
OCD
Roger555's Avatar
There is always a rapid warming period leading up to an ice age
Old 01-21-2011, 06:39 PM
MechEng
03tLsNBP's Avatar
also Global Warming is not felt as significantly in North America haha
Old 01-21-2011, 06:43 PM
babylou772's Avatar
The lowest I've seen so far on mine is -8 and that was yesterday morning but with the wind chill it was like -25. Me and my car are both from FL and we got stuck here
Old 01-21-2011, 06:47 PM
Chapter Leader (Central New Jersey)
07tl-s6spd's Avatar
damn thats cold bro.....i dont think i could survive...lol
Old 01-21-2011, 06:58 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Wow, that's colder than up here where I live.
Old 01-21-2011, 09:38 PM
Plastic schmastic
jimmyl's Avatar
THAT is why we don't complain when it's 110 here in August!!! I'll take that trade any day.
Actually, since I just came from diesel Mercedes, starting in cold weather hasn't even been on my radar. Starting a diesel in the cold can really be an adventure, especially when they are above 200,000 or 300,000 miles. My little 240D with about 315K on the engine was not a fan of starting in temps below freezing.....
Quick Reply: -32 Below Zero today! in Wisconsin
