Check out the photo and tell me if you can identify this type of bolt that is the top caliper to hub retainer bolt. It looks like a torque/star, but it has too many points. It’s the bolt on the right.
looks like some special mechanic has taken the caliper off before and throw that one original of the bolt away. From what i seen you got a Temper bit head, check online for Temper key, if you gonna remove the caliper bolt be extra caution because these caliper knowing for strip the threads.
BTW here what the original bolts should looks like.
