2007 TL Switchblade Key
#321
Originally Posted by FLBusa
He did say it was thinner...
#322
Originally Posted by Black_05_TL_6SP
I am hoping the new driver 1 comes in today, if not, it should be here tomorrow. Once I have it, I am going to take it apart and work on getting the mold made. Ocne I have the mold, it takes about 10 minutes for it to set up. I will keep everyone posted.
The issue is that there are a ton of little details in the plastic part that dictate the stops of the button, the spring guide, the axial rotation (I think that's the right term), etc.
I ended up making the mold in a small plastic cup with the blank aligned vertically, with the plastic part down and the metal key blank about 50% covered. I had hoped this would allow me to put my machinable blank into the resin before it hardened yet retain the proper depth and alignment necessary.
In theory that was fine, but the reality was that the mold wasn't good. Maybe someone with more molding experience could shine some light on the best way to do this. Lord knows, I've got plenty of material left I can play with. I just cannot visualize a better way.
TIA.
-chad
#323
Originally Posted by moda_way
If you have length x width x thickness, the TL key is thicker, longer, but not as wide. The trick will be to mill it so that the tumblers fall correctly since cutting the same profile will make the tumblers fall deeper.
#324
tuning / modding newbie.
just curious, and I don't have time to read 13 pages, so I apologize if this has been covered already, but can you just replace the ingition keyhole in the steering column to the 07 so you can use the 07 key without such drastic modifications?
*blank stare*
*blank stare*
#326
Ryan Christopher
*blank stare*
*blank stare*
#327
Ryan Christopher
Originally Posted by carpecervisi
I tried the mold method and it didn't work. Now granted, I've never done it before, but I wasn't able to figure out the best method for making sure the plastic part was perfectly usable.
TIA.
-chad
TIA.
-chad
#328
Originally Posted by lembowski
I was looking at it, and I do not think there will be enough width to make the 90* on both sides of the blade.
#329
Trucki!!
Hard to tell from a blurry picture (no offense intended). If you have a dial caliper or micrometer you can measure each and be 100% sure. Machining may not be an option if there's not enough material to make a step.
but with my nifty ruler, it looks alittle less than a cm
#330
Well... amid a few doubts and no real key in hand I'm still going to machine up a prototype. So far I have a CAD model ready to go and hopefully will have something completed by this weekend.
Prototype Blank
Prototype blank after machining
Prototype Blank
#331
Sorry I work for an Insurance Brokerage.............so no micrometers around here
#332
Why I watch sci-fi...
FLBusa---
Now, can you just buy the key blanks seprate from the rest of the remote? If so, it may be cheaper all around (or at least for you) to have you only buy the blank and have us buy the rest. It would limit your libality as far as remote breakage and save on shipping.
#335
FYI, I too have successfully disassembled and reassembled the TL key. I've also removed the immobilizer chip and programmed the transmitter to work with my TSX. Next thing to do is figure out how the hell I'm gonna get a key epoxied in there. This key mod is 2x as difficult as the USDM Accord mod. It is not for the faint of heart. Acura/Honda did a good job making the immobilizer chip nearly impossible to get out, but I was able to get it out.
So far, I'm 50% the way there.
#336
Summer is Coming
TIA.
-chad
TIA.
-chad
http://stores.ebay.com/Orthodealer_I...QQftidZ2QQtZkm
#337
FYI, programming the transmitter took about 20 seconds for my '05 TL. It works perfectly.
I'm just waiting for the JB Weld to dry overnight, and I'm going to try to put it all back together in the morning.
#339
One on the right for me
Originally Posted by tidus888
hey guys.. do u think is it actually possible to do a spot weld? or too small?
That's what I was considering. I haven't paid too much attention to the pics yet to determine whether its possible or not. When I'm not so lazy I'll but a key and see if it works or looks feasible.
#340
That's where the weakness lies, not in the key itself...in that plastic housing. The dremel'ed '05 key is just as strong as the '07 blank, as they are both a solid piece of metal. If you pulled out the '07 blank in order to weld it, you might as well just stick your modified (and stonger) '04-'06 blank in there.
#343
From the JB Weld website:
Q: Is there anything that J-B Weld WON'T bond to?
A: J-B Weld will not adhere to, or bond well to:
Any flexible rubber surface
Leather
Vinyl
Canvass
Polypropylene plastic
Polyethylene plastic
PLEASE tell me that the last two aren't what the damn transmitter is made from....
Leather
Vinyl
Canvass
#344
^ - good to know. Hopefully when I actually get around to doing this there will be someone who has a fully functional key
I'm about 80% pleased with mine, mainly due to two reasons. Since the 05 blank is thinner than the 07 blank, it was all but impossible to make the piece to spec after you hacksaw the thing apart. The other thing with mine is that I must have messed up one of the stops a bit because my key opens too far, like 10* or so.
Anyway, regarding the width of the blanks:
07: 0.353"
05: 0.383"
I have no idea what the tolerances of the switch is, but hopefully this will still work out.
-chad
#346
Trucki!!
Originally Posted by cTLgo
although more expensive, has anyone thought of replacing the lock cylinder?
But I'm still thinking of a way to cleanly chop the stock blade out. There has to be some type of blade/machine that can precisely cut it
#347
I think several of us have already done the JB Weld method at least. Mine works fine, but I had to butcher my valet key to do it. There is definitely a lot of finesse work that needs to be done after the epoxying of the plastic back together to ensure you get the proper fit onto the spindle. You also have to make sure that you are careful with the application of JB because there are specific cutouts that have to be correct to make the "switchblade" part work properly.
07: 0.353"
05: 0.383"
-chad
07: 0.353"
05: 0.383"
-chad
#349
Team Anthracite
heres my plan... i got a copy of my 06 key (without imobi for $4) tried the switches.. it works..
planning to cut the key on an angle... then cut the orginal 07 key and match the angle... then spot weld the two together and get the dealer to program the imobi for $40... i think that should work... and plus.. welding the two pieces of metal together might look ok too... what do u guys thing?
#350
I wonder if something like this is possible..
Using a CAD program, design the plastic piece that holds the 07 blank to the transmitter, and then using CNC machines just mill that out of some AL so its light weight and then we can just attach that to a 05 vallet key and then you should be able to insert that into 07 transmitter. I think this will be solid and should never break off.
Thoughts?
Thoughts?
#351
So I got the key in today, and Im waiting to see some of the responses on here. I was thinking about just cutting my o5 tl valet key, and welding it to the new one, but Im going to wait and see what everyone decides on doing.
#352
Can you cut the 05 key and weld it on to the 07 switchblade? I keep seeing that there is a sensor or something inside the key that has to come out. It looks real confusing and I just thought a simple weld would do the trick.
#354
'04 6mt Pearl
Thoughts?
Thoughts?
One other thing about molding or CNC. The 05 keyblank is thinner than the 07 so there might be too much play in the joint. You'd need to CNC/mold the hub a wee bit thicker than the 07's to compensate.
#355
Originally Posted by triggle
I wonder if the imobilizer chip would work surrounded by aluminum as opposed to plastic.
#356
Ryan Christopher
#357
I did ask the dealer about this. It runs $500 for the four locks for the car. But you still have to install them.
#358
Trucki!!
Originally Posted by x420actionx
Four locks? what do you mean? I thought the question also pertained to just changing the whole ignition, to the new 07' ignition, so that it could just use the new key. Is this possible? How expensive is this really? If what you say is true then its probably going to be on top of the $500 dollars...oh boy
4 locks.........
Drivers Door
Ignition
Glove Box
Ski Shoot??
#359
Well you have to change the other locks if you wan to use your key on the other locks in the car
4 locks.........
Drivers Door
Ignition
Glove Box
Ski Shoot??
4 locks.........
Drivers Door
Ignition
Glove Box
Ski Shoot??
This is better if you have a few hundred to spare, plus its a sure thing, not something that may or may not work...
#360
GO DAWGS!! SICK'EM!!
anyone has any sucess of removing the 3 screws that is holding the key in the key fob? I am having a hard time remove it...any idea will be helpful, thanks.
