2007 TL-S "bounces"
Old Feb 4, 2023 | 09:10 PM
Elliotak's Avatar
2007 TL-S "bounces"
Good day, evening, morning all.....I hae a 2007 TL-S, and the front end "bounces". Tires all balanced-but it straight up "bounces". Any idears? I was thinking wheel bearings-and I cannot for the life of me remenber when I did them last....any clues are appreciated!!
Thanks!
Old Feb 4, 2023 | 10:16 PM
Aman's Avatar
Your Friendly Canadian
Shocks are the first thing I would look at.
Old Feb 5, 2023 | 10:31 AM
WDPanda's Avatar
Bouncing on corners or on acceleration?
It's axles if it's bouncing during hard acceleration
Old Feb 6, 2023 | 06:23 PM
twokexlv6coupe's Avatar
Shocks.
Old Feb 6, 2023 | 07:55 PM
Pair of TLs's Avatar
Did somebody remove the struts??
Old Feb 7, 2023 | 06:46 AM
Elliotak's Avatar
"bounce" issue
Both struts were replaced less than 3K miles ago. The "bounce" seems most noticable at slow speed, cold engine, minimal throttle.
Old Feb 7, 2023 | 08:32 AM
Cold, flat-spotted tires? Wheels bent?
Old Feb 7, 2023 | 09:29 AM
BROlando's Avatar
Wow with such a vivid description of the problem, I'm surprised it isn't solved yet.
"My car bounces. Lmk."
Old Feb 7, 2023 | 05:29 PM
csmeance's Avatar
Throwing parts randomly really won't help but lighten your wallet. You'll need a mechanic to check over the front suspension and check the lower control arm bushings, shocks, springs, ball joints, tie rod ends, etc.
More than likely there are some damaged/worn components causing this issue.
TL-Sexi07
Nov 25, 2012 12:05 PM
tonto340
Sep 3, 2007 10:30 AM
Will Y.
Feb 22, 2007 10:24 PM
Armydog14
Oct 28, 2006 05:13 PM
