2007 Side Mirror Blinkers
Old 05-10-2007 | 01:35 PM
  #121
SilverUA5's Avatar
Anyone know if the silver from the '06 is the same as the '07? Thanks.
Old 05-11-2007 | 09:25 AM
  #122
Ac Man's Avatar
No, they are not the same. But I have an '05 SSM, and the '07 ASM do not look that different to me. Believe me, I was about get my mirrors painted too, but when I received them and compared it to my car I couldn't tell the difference. Trust me, it is not noticeable at all or I would have spent the money to paint them.
Old 05-11-2007 | 12:22 PM
  #123
cM3go's Avatar
How close is carbon gray pearl to Anthracite?
Old 05-11-2007 | 12:39 PM
  #124
Tonywp75's Avatar
Dont Touch My Car !!!
I was at the dealership yesterday for an oil change, so i went outside to check out the color. The carbon grey is darker with less metallic flakes...i think.
  #125
rockyfeller's Avatar
King of NYC
CGP is totally off from AM
Old 05-12-2007 | 03:17 AM
  #126
BAO-7786's Avatar
check out my :
http://i155.photobucket.com/albums/s...t/DSCF0730.jpg
http://i155.photobucket.com/albums/s...t/DSCF0737.jpg
Old 09-21-2007 | 02:05 PM
  #127
Evader's Avatar
Let's Go Pens
I'm going to resurrect this thread and hopefully I don't get flamed for it. I don't really have a lot of time right now to do an extensive search. I'm basically looking for confirmation on how to remove the plastic cover off the signal mirrors. I'm sure you just use a flat head screwdriver (with a cloth obviously) but at which end should I pry it off from? I'm considering changing these to either a blue or red bulb and also want to tint them for a more stealthy appearance. I just need to find some patience to also do my front sidemarkers, as i'd like to mod them to red to match the rear - illegal, who cares?
Old 09-21-2007 | 04:14 PM
  #128
THTL's Avatar
so does CPG color different from Anthracite .
thanks.
Old 09-26-2007 | 11:22 PM
  #129
yourit's Avatar
TL-see
anyone with a detailed instructions with pictures of how to do 2007 tl side view mirrors swap on a 06? I'm not sure how to take off the door panel and how to run the extra wire for powering the blinker?
Old 09-27-2007 | 03:45 PM
  #130
ARX-01b's Avatar
Mine are due in next week. I guess I could do it if nobody else has already done it.
Old 09-27-2007 | 04:11 PM
  #131
THTL's Avatar
please do that
Old 10-07-2007 | 09:02 PM
  #132
ARX-01b's Avatar
What parts need to be broken off the 07 side markers to make them fit an 04?
Old 10-07-2007 | 10:04 PM
  #133
Royce Han's Avatar
B A N N E D
nothing needs to be broken, just the wire plug connector needs to be modified to fit. its still the two same wires in the same +and - locations but a wider connector so it wont be a direct fit. i chopped extra plastic off the wider plug and used super glue but now that i think about it, i shouldve just chopped the connectors off and hardwired instead with some heat shrink tubing over it.
Old 10-08-2007 | 05:19 PM
  #134
THTL's Avatar
bump
Old 10-13-2007 | 07:29 AM
  #135
05tlguy's Avatar
Question hey royce...
hope you are still active on this topic royce----or anyone!. i am trying to figure out how you snaked/ routed the power wire from the side mirror blinkers to the blinker bulb{s} up front. the mirrors look awesome and no more blind spots, but they would look a lot nicer if i coud get them to blink!! lol
p.s. can you be specific as to the routing from door through frame in particular?.. thanks all
Old 10-13-2007 | 08:09 AM
  #136
Royce Han's Avatar
B A N N E D
well, the only way i know to get them to blink was to physically run a wire through the molex-boot/jamb and in through the fenders and tap into the middle wire of the three in the front blinker bulb. both sides are the same for the tapping into the middle wire. as far as how to get them throught the rubber molex, oh boy, hope you have small wrists and a tolerance for pain. my first time was kind of ghetto , i ran the wire exposed in the jamb and wrapped it in that plastic wire sleeve used for installs- i cant think of the exact name for it, dangit! but to redo it better i basically i undid the 2 halves of the rubber seal in the jamb, took a hot needle to melt a hole through the 2 halves of the molex. ran the wire through the 2 melted holes and then clicked the 2 halves back together to form a tight seal again. its not easy handling a hot needle in that small of space while trying to see what it is you are even doing and with a wire plug that has no slack in it. just hope you have a lot of will power ,lol
Old 10-19-2007 | 05:14 PM
  #137
THTL's Avatar
Is there a way to hook up the 07 TL side mirrors onto an 05 TL to have it blink with the signals and also lit up with the two front doors opened.
Old 10-20-2007 | 08:39 PM
  #138
Tripnbeats's Avatar
I did the install on mine with no problems and when the doors are opened Im guessing unlocked u mean... they dont blink on that circuit if they did theyd be on all the time thats the parking light circuit
Old 06-05-2008 | 10:03 AM
  #139
oneclu's Avatar
is there a DIY for this anywhere?
Old 06-06-2008 | 06:47 AM
  #140
DaddysOnehotAck's Avatar
I brought mine from ebay for $350.00,last I checked they when up??.........
Old 06-06-2008 | 01:07 PM
  #141
HONgDA's Avatar
2005 TL (7/07-8/29/09)
I hope the 4g TL side mirrors will fit the 3g TL.
Old 12-26-2008 | 06:58 PM
  #142
Simon151's Avatar
3rd Gear
You need an l-e-d load equilizer, you can get them on ebay cheap, they will make your lights bling normally again, led lights have low resistance, so your car thinks that there is a blown bulb on the car, so it blinks fast to alert you of a blown bulb.
Old 05-14-2010 | 03:06 PM
  #143
07tl-s6spd's Avatar
Chapter Leader (Central New Jersey)
Originally Posted by vc123
those TL mirror blinkers rn't nice u should check if u can get the TSX installed instead.. those side blinkers r too thick looks weird the TSX ones looks muchbetter
tl blinkers are way better than the tsx....
Old 05-17-2010 | 02:34 PM
  #144
smsTL's Avatar
Sǝxy Timǝ in my
haha ancient thread, check out the date. lol
rockyboy
08-04-2024 10:35 AM
Type S Zero
02-17-2016 02:37 PM
sockr1
10-01-2015 01:31 AM
hand123
09-10-2015 09:27 AM
Quick Reply: 2007 Side Mirror Blinkers
