2006 vs 2007 Differences
Old May 11, 2008 | 11:04 PM
Bike Effects's Avatar
2 TL Owner
I am going to be looking for an '06 shortly but I wonder if I should spend the extra money and buy an '07. What are the differences on the '07 vs the '06?
Is there a table somewhere that shows what changed on the 3G cars from '04 through present?
Old May 12, 2008 | 12:03 AM
Clean>Rice's Avatar
Ricer Killer
the 07 has a few changes. In the back, the tail lights have two whites slits. The front has fog lights. also, its a little louder for some reason. i used to get a ride in my friends 06 but now when im in my 07, there feels like there is more drone and is loud when i gun it...and i dont have aftermarket exhausts, yet. im sure there are more differences (minor).
Old May 12, 2008 | 12:33 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
the rims... too lol
Old May 12, 2008 | 12:36 AM
Bearcat94's Avatar
AZ Community Team
There was a thread and csmenace listed pretty much *all* the model year changes. Off the top of his head, IIRC. Pretty impressive.
Try searching his posts with a couple of likely search words.
Old May 12, 2008 | 12:41 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
With the '07 you get TPMS, foglights in the lower front grill (instead of in the headlight housing), and updated Navi DVD, a different rear bumper (has a grill insert), sideview mirror blinkers, and different tail lights...off the top of my head. You also DON'T get the option of a manual transmission, unless you go Type-S.
Old May 12, 2008 | 01:20 AM
Bearcat94's Avatar
AZ Community Team
Originally Posted by csmeance
Ways to tell TL's Apart:
A 2004-2006 TL with a 6 speed manual will have huge brake capilers in the front that are black.
A 2004-2006 TL with 5 Speed Automatic has silver small brake capilers all around.
A 2005-2006 TL have an extra line of stitching on the inside
A 2005-2006 TL have the seatbelt anchored to the seat and not the floor
A 2005-2006 TL has a A symbol that is part plastic chrome, the 04 has a full plastic one.
A 2004-2006 TL has solid RED tail-lights
A 2004-2006 TL with Quartz and Ebony interior have Carbon Fiber trim
A 2004-2006 TL with Parchment or Camel interior have ORANGE WOOD trim
A 2004-2006 TL has a 4 spoke steering wheel
A 2004-2006 TL says HONDA ON WINDOWS AND EXTERIOR PARTS
A 2004-2006 TL has FULL AMBER reflectors in the headlights
A 2004-2006 TL has RED rear side markers
A 2004-2006 TL has satin exterior
A 2006 TL has a rectangle indent in the rims to have the TPMS sensor
A 2007-2008 TL has euro blinkers on the side-mirrors
A 2007-2008 TL has Fog lights at the bottom of the bumper with DRL's where the fogs were on the 2004-2006 TL
A 2007-2008 TL has a honeycomb cutout on the rear bumper between the muffler
tips
A 2007-2008 TL has larger grills on the front
A 2007-2008 TL has clear lenses Tail-lights with red parts within
A 2007-2008 TL has a 3 spoke steering wheel
A 2007-2008 TL has ACURA ON THE WINDOWS AND EXTERIOR PARTS
A 2007-2008 TL BASE has fake black wood interior trim
A 2007-2008 TL BASE has a clear middle section of the tail-light
A 2007-2008 TL Base has satin trim on the exterior
A 2007-2008 TL-S has a fake Carbon Fiber interior trim
A 2007-2008 TL-S has half clear, half Amber front reflectors
A 2007-2008 TL-S had grey rear side markers
A 2007-2008 TL-S has Chrome Trim instead of Satin Trim
A 2007-2008 TL-S had Huge Black Capilers in the front, both on AUTO AND MANUAL
A 2007-2008 TL-S has metal racing pedals
A 2007-2008 TL has a 10 spoke 17 inch rim while the 2004-2006 has a 5 spoke star rim
A 2007-2008 TL-S has 17 inch GUNMETAL rims.
A 2007-2008 TL-S has black rear capilers
A 2007-2008 TL-S has gunmetal in the tail-lights
A 2007-2008 TL-S has quad exhaust
A 2007-2008 TL-S has vertical stitching on the door-panels
A 2007-2008 TL-S has TYPE-S embossed into the headrests
Yes, I typed these all up.
I posted things in that list that were easily visible, to an extent, I guess that the Type-S emblems Should be on there, but for the red-lighting, you can only see that when the car is on...
IF you wish to add these smaller details, here they are:
2004-2006 TL ALL, the underside of the headrest, and rear arm-rest side (near the door) is vinyl
2007-2008 TL ALL, the underside of the headrest is felt, along with the rear arm rest
2004-2006 TL NAV uses 3.xx version, XM RADIO ONLY
2007-2008 TL NAV uses 4.xx version, XM NAV TRAFFIC, MP3/WMA, AUX, Dobly Prologic 2 added
2007-2008 TL-S ANC added
2004-2006 TL ALL - gauges are black with blue semi-ring, red needles and white, MID in right, PRNDML in left cluster
2007-2008 TL BASE - Gauges have brushed background, blue rings around, white numbers, red needle, MID in center, PRNDML in right cluster
2007-2008 TL-S - Gauges have brushed background, RED rings around, white numbers, red needle, MID in center, PRNDML in right cluster
2004-2006 TL NAV- HFL, Navi buttons in bottom left corner of steering wheel
2007-2008 TL NAV- HFL, NAVI, MID buttons directly on bottom of steering wheel face
2004-2006 TL NON-NAV - radio display and temperature display together in 1 unit, NO COMPASS, Manual Clock adjustment, Blue backlight added either in 2005 or 2006
2007-2008 TL NON-NAV - radio display and temperature display appear to be 2 units, Compass, Manual Clock, white text, no backlight
2004-2006 5AT TL ALL black leather shifter standard
2007-2008 5AT TL BAse, black leather shift knob
2007-2008 5AT TL-S Black Leather with carbon fiber center shift-knob
2004-2006 TL Standard suspension firm, yet soft
2007-2008 TL BASE- Suspension softer than 2004-2006
2007-2008 TL-S - Suspension firmer than 2004-2006, but less then 2004-2008 ASPEC
2004-2006 TL 3.2 ALL engine cover simple plastic with manifold uncovered
2007-2008 TL 3.2 BASE engine cover plastic covering entire manifold with A symbol
2007-2008 TL-S 3.5 Engine cover plastic covering entire manifold with A symbol, 3.5 In red on cover
2004-2006 TL Battery cover clips on
2007-2008 TL ALL battery cover has different attachment system with knob
2004-2006 TL Air box rectangular
2007-2008 TL Air box With cut on one side
2004-2006 TL, Headliner and pillars are grey
2007-2008 TL BASE - Headliner and pillars grey
2007-2008 TL-S- Headliner is ebony along with pillars
Plus a bunch of other stuff that I can't think of right now..
https://acurazine.com/forums/showthread.php?p=2014669
Old May 12, 2008 | 02:36 AM
06 Acura TL A-Spec's Avatar
The 06 TL also has the tpms too.
Old May 12, 2008 | 08:30 AM
vinnier6's Avatar
3 spoke steering wheel vrs the 06 4 spoke...mid controls on the steering wheel....nav traffic...and the 07 up also has day time running lights....
Old May 12, 2008 | 03:58 PM
kenny5's Avatar
Don't forget the most obvious ... the 07 is one year newer than the 06
Old May 12, 2008 | 08:26 PM
Tvtchr222's Avatar
The 07 with Nav has a backup camera. 06 doesn't.
Old May 12, 2008 | 09:00 PM
jguerra23's Avatar
Looking for new mods
the MID is the center of the cluster. DLR , different A-spec body kit.
Old May 12, 2008 | 09:10 PM
csmeance's Avatar
What type of car are you looking for, a car that has the perfect blend of sportiness and luxury, or a more a car that is a bit more cushy, and has hidden attributes when called on?
If the first, the TL from 2006 is right for you, it has a slightly firmer suspension that the 07 base, has Carbon fiber trim and also is a bit sporty. As well, If you chose this option, take a look at the 2007 TL-S, it is sportier, as it has a better suspension, more power and many other attributes that will make you love to be in it.
If the second, the TL base is right for you, it has the softest suspension that the 3G TL has ever had, it has black-wood trim and is elegant. As well, it has the same motor that the TL from 2004-2006 has, and has the same amount of power.
Old May 12, 2008 | 10:24 PM
anx1300c's Avatar
I think the 04-06 wheels are alot sportier than the newer ones, too. I didn't know they softened the suspension for '07.
Old May 13, 2008 | 12:24 AM
2 TL Owner
I'm in awe! Thank you all and special thanks to csmeance. A terrific help.
Old Mar 19, 2020 | 10:10 PM
Jonathan F. Hardt's Avatar
I discovered the hard way today that there subtle differences in '06 only. There are several parts that look exactly 2004-2008 but they will not cross. Here is my experience. I got hold of both headlight assemblies brand new after market, the part numbers for these stunning beauties are for 2005. Took it to my body man, then he showed me the mounts, bulbs, igniter, wires etc. were similar but not identical . I was very disconcerted with Acura, heart broken. I went way down the rabbit hole, many are aware, but no one knows why 2006 is in fact different. Anyway, once I was driving her again I forgave Acura and all was right with the world..
Old Mar 20, 2020 | 06:19 AM
truonghthe's Avatar
way to bump a 12 years old thread
4drviper
Apr 23, 2025 07:13 PM
Euro4gen
Dec 12, 2015 03:14 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
LeVeL
Oct 18, 2015 04:19 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
