2004 v. 2008
Old Aug 7, 2008 | 02:17 PM
snax's Avatar
Snax
2004 v. 2008
Just moved back to the US after living in Shanghai for past 2 years.
I had a new 04 and sold it in 2006 before I left for China.
What is the difference (if any) between 04 and 08 TL (no type S)?
How would you compare the 08 TL to the 09 TSX?
Old Aug 7, 2008 | 02:33 PM
jmkiang's Avatar
zaino'd
Wikipedia "Acura TL". They have a good breakdown of the changes.
Old Aug 7, 2008 | 02:48 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
1. different rims.
2. different head lights.
3. fog lights.
4. different less less hp(259).
5. different double stitching seats.
4. different tail lights.
5. different steering wheel.
6. differ key.
7. different grill.
8. led mirrors(turn signals)
9. different gauge(color)
10. different motor covers.
cant think of nothing els... don't buy a tsx.. its a nice car if you didn't have a tl b4 the fact.. I had a 09 tsx as a loner and it was nice but to small and to slow on high rpm's. get a used type s instead of a new base.
Old Aug 7, 2008 | 02:51 PM
TeknoKing's Avatar
^ 04-08 base TL, hp did not change...
08 TL vs 09 TSX...it's your preference really... 2009 is the next generation of Acura TSX, so it has newer gadgets, but a TL will be much more fun to drive...
Sit in both, and choose for yourself.
Crucifer's Avatar
By all reviews and ratings 04 TL's were the best TL's ever made.
Though you can't go wrong with a TL either way.
Old Aug 7, 2008 | 02:52 PM
TeknoKing's Avatar
That ain't the peace pipe you are smoking I bet...
04 TL > my 08 TL-S?
Old Aug 7, 2008 | 03:20 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
from what i know the 04 05 has 270 and the 06 07 08 has 259..
Old Aug 7, 2008 | 03:28 PM
1995hoo's Avatar
Keep Right Except to Pass
Originally Posted by ac08odl
1. different rims.
3. fog lights.
6. differ key.
7. different grill.
11. The 2004 had the 6MT available; the 2008 does not unless you buy the Type-S.
The actual horsepower did not change in the base TL. Horsepower is now calculated differently than it was in 2004 and the result of the new method is a lower number. But the actual horsepower remains the same.
Old Aug 7, 2008 | 03:29 PM
jmkiang's Avatar
zaino'd
^ Different HP rating method... Acura hasn't changed the engine from 04-08.
Old Aug 7, 2008 | 05:28 PM
csmeance's Avatar
ys to tell TL's Apart:
A 2004-2006 TL with a 6 speed manual will have huge brake capilers in the front that are black.
A 2004-2006 TL with 5 Speed Automatic has silver small brake capilers all around.
A 2005-2006 TL have an extra line of stitching on the inside
A 2005-2006 TL have the seatbelt anchored to the seat and not the floor
A 2005-2006 TL has a A symbol that is part plastic chrome, the 04 has a full plastic one.
A 2004-2006 TL has solid RED tail-lights
A 2004-2006 TL with Quartz and Ebony interior have Carbon Fiber trim
A 2004-2006 TL with Parchment or Camel interior have ORANGE WOOD trim
A 2004-2006 TL has a 4 spoke steering wheel
A 2004-2006 TL says HONDA ON WINDOWS AND EXTERIOR PARTS
A 2004-2006 TL has FULL AMBER reflectors in the headlights
A 2004-2006 TL has RED rear side markers
A 2004-2006 TL has satin exterior
A 2006 TL has a rectangle indent in the rims to have the TPMS sensor
A 2007-2008 TL has euro blinkers on the side-mirrors
A 2007-2008 TL has Fog lights at the bottom of the bumper with DRL's where the fogs were on the 2004-2006 TL
A 2007-2008 TL has a honeycomb cutout on the rear bumper between the muffler
tips
A 2007-2008 TL has larger grills on the front
A 2007-2008 TL has clear lenses Tail-lights with red parts within
A 2007-2008 TL has a 3 spoke steering wheel
A 2007-2008 TL has ACURA ON THE WINDOWS AND EXTERIOR PARTS
A 2007-2008 TL BASE has fake black wood interior trim
A 2007-2008 TL BASE has a clear middle section of the tail-light
A 2007-2008 TL Base has satin trim on the exterior
A 2007-2008 TL-S has a fake Carbon Fiber interior trim
A 2007-2008 TL-S has half clear, half Amber front reflectors
A 2007-2008 TL-S had grey rear side markers
A 2007-2008 TL-S has Chrome Trim instead of Satin Trim
A 2007-2008 TL-S had Huge Black Capilers in the front, both on AUTO AND MANUAL
A 2007-2008 TL-S has metal racing pedals
A 2007-2008 TL has a 10 spoke 17 inch rim while the 2004-2006 has a 5 spoke star rim
A 2007-2008 TL-S has 17 inch GUNMETAL rims.
A 2007-2008 TL-S has black rear capilers
A 2007-2008 TL-S has gunmetal in the tail-lights
A 2007-2008 TL-S has quad exhaust
A 2007-2008 TL-S has vertical stitching on the door-panels
A 2007-2008 TL-S has TYPE-S embossed into the headrests
posted things in that list that were easily visible, to an extent, I guess that the Type-S emblems Should be on there, but for the red-lighting, you can only see that when the car is on...
IF you wish to add these smaller details, here they are:
2004-2006 TL ALL, the underside of the headrest, and rear arm-rest side (near the door) is vinyl
2007-2008 TL ALL, the underside of the headrest is felt, along with the rear arm rest
2004-2006 TL NAV uses 3.xx version, XM RADIO ONLY
2007-2008 TL NAV uses 4.xx version, XM NAV TRAFFIC, MP3/WMA, AUX, Dobly Prologic 2 added
2007-2008 TL-S ANC added
2004-2006 TL ALL - gauges are black with blue semi-ring, red needles and white, MID in right, PRNDML in left cluster
2007-2008 TL BASE - Gauges have brushed background, blue rings around, white numbers, red needle, MID in center, PRNDML in right cluster
2007-2008 TL-S - Gauges have brushed background, RED rings around, white numbers, red needle, MID in center, PRNDML in right cluster
2004-2006 TL NAV- HFL, Navi buttons in bottom left corner of steering wheel
2007-2008 TL NAV- HFL, NAVI, MID buttons directly on bottom of steering wheel face
2004-2006 TL NON-NAV - radio display and temperature display together in 1 unit, NO COMPASS, Manual Clock adjustment, Blue backlight added either in 2005 or 2006
2007-2008 TL NON-NAV - radio display and temperature display appear to be 2 units, Compass, Manual Clock, white text, no backlight
2004-2006 5AT TL ALL black leather shifter standard
2007-2008 5AT TL BAse, black leather shift knob
2007-2008 5AT TL-S Black Leather with carbon fiber center shift-knob
2004-2006 TL Standard suspension firm, yet soft
2007-2008 TL BASE- Suspension softer than 2004-2006
2007-2008 TL-S - Suspension firmer than 2004-2006, but less then 2004-2008 ASPEC
2004-2006 TL 3.2 ALL engine cover simple plastic with manifold uncovered
2007-2008 TL 3.2 BASE engine cover plastic covering entire manifold with A symbol
2007-2008 TL-S 3.5 Engine cover plastic covering entire manifold with A symbol, 3.5 In red on cover
2004-2006 TL Battery cover clips on
2007-2008 TL ALL battery cover has different attachment system with knob
2004-2006 TL Air box rectangular
2007-2008 TL Air box With cut on one side
2004-2006 TL, Headliner and pillars are grey
2007-2008 TL BASE - Headliner and pillars grey
2007-2008 TL-S- Headliner is ebony along with pillars
the 07+ has the switchblade keys too
Old Aug 7, 2008 | 05:59 PM
JwongTLS's Avatar
tips
NICE..everything u need to know about the diffrence in models..sticky icky??
Old Aug 7, 2008 | 07:13 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
LMAOOO... DAMNNNN
Old Aug 7, 2008 | 07:20 PM
snax's Avatar
Snax
All are excellent post and are very informative. Many thanks.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
TLguy42
Sep 26, 2015 11:27 AM
2Quik
Sep 23, 2015 01:03 PM
