'07 Spark plug change
Old Sep 14, 2011 | 07:12 PM
Onyx97's Avatar
Can you guts tell me the tools I will need to change the plugs on my 07 TL and what's the best way to get the 3 plugs that are in back of the engine out. I already looked at the DIY but it wasn't clear enough for me on the spark plug portion.
Onyx97's Avatar
* Guys
Old Sep 14, 2011 | 07:33 PM
Pat04TL's Avatar
Followed DIY for the general procedure. I had to take the strut bar off to get at the back three. Once removed, the rest was easy.
Old Sep 14, 2011 | 07:36 PM
guitarplayer16's Avatar
Yeah, definitely take off the front tower strut bar.
Way more room to get to the rear spark plugs.
Old Sep 14, 2011 | 08:28 PM
Onyx97's Avatar
Does the strut bar have to be torqued down when you put it back on ?
Old Sep 14, 2011 | 08:33 PM
16 lb/ft
Old Sep 14, 2011 | 08:34 PM
BukvaMan's Avatar
i tighten mine until sweat starts coming out underneath the nuts Its good to torque down everything but its not necessary really. I changed my sparkplugs not to long ago, its probably the easies thing you can do on the car... well aside from changing the air filter . Just tighten the spark plugs snug or tight enough. But the bar i tighten like a maniac , just joking but make sure its tight good.
Old Sep 14, 2011 | 10:31 PM
Bearcat94's Avatar
AZ Community Team
As you stand facing the engine, the one in the back on the left is a stone cold bitch. The other two are easier, just because of room/reach.
Here's the trick:
1st make sure you've got a plug socket with the rubber grabby thing inside. Attach that to a 6" extension and put it in the plug hole. Then attach a 3" extension to that.
If you have the ratchet and a full extension and the socket, all together, you can't manuever the rig. Putting it together in pieces makes it 10x easier.
When you replace the plugs, put the plug int he socket with the rubber grabby thing and the 6" extension - you should be able to start the plug with that by hand. Also, use a dab of anti-seize on the threads. When hand start the threads, make sure you don't cross-thread them. Tighten to torque (which isn't very much).
Old Sep 15, 2011 | 02:40 PM
Onyx97's Avatar
Thanx guys it's all done, saved myself a chunk of cash
pstomps
Feb 20, 2017 03:29 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Sep 17, 2015 10:16 AM
Aleax
Sep 11, 2015 11:31 AM
NSolace
Sep 3, 2015 08:14 PM
