06 TL: Custom lower grille's - Where to buy? Picture intalled grille?
Have an 06 TL and the ugly part of the car, in my opinion, are the two lower grilles. Anyone have a source to buy custom grilles? Any pictures out there? Google provides nothing. (seems like no one makes 06 TL custom grilles)
Retired and Loving It
OOOOOPPSSSSSSSSSS sorry about the size of the pics, thought they would be resized! little blurry too as I was in the parking garage
Nice grill and thanks for the pics.
I have a NBP and i'm disliking the grill. I want to do something about it. Would the grill look good on my car or does anybody here have a NBP with the front grill that i can check it out?
Here is a better pic of the openings in the grille, it is fairly open. With larger openings you start to see more of the stuff behind the grille and may need to paint it out black or something.
for a large selection of materials check out McNichols Company www.mcnichols.com
pohljm That's what I'm looking for.
pohljm your car looks great....big too!........ Real big!....... nice photos!........Do you know what type mesh that is? Where did you buy it? Yours looks perfect. Thank you for your assistance..
Since the photos I put my a-spec kit on so I polyurethaned the mesh so that it would keep the galvanized finish since I wont be able to take them out now that the lip is on. It works perfect in that the dimension that you need to trim it to is 3.5" and that happens to fall on the module of the mesh so that there are no sharp legs or edges when you cut it down. you will have some on the ends when you trim it legthwise because it is a tapered shape. Good luck with your mod.......its hella easy
Originally Posted by Slammed_JDM
how do u remove the lower grills. I have an A-Spec lip if it makes any difference?
Thanks,
Jonathan
Thanks,
Jonathan
B A N N E D
Originally Posted by pohljm
well you need to remove the a-spec lip first in order to remove the grill, once that has been done... 7 screws, 2 bolts, and 2 clips later........the grills are held in by clips around the perimeter of the frame and you can reach most all of them by reaching around the backside from below. then the grilles pop straight out.
is there any way to prevent from removing the lip. Sounds like a PITA to take the lip or bumper off?
Team Nighthawk member
I spray painted the mesh black.
MaFreCola, That looks nice on the dark painted cars, I did that first too and then went back to the silver finish for more contrast, also in the week or so I had the black on some of the paint chipped off from bugs or something. I would definetly prep the galvanized finish better if I was planning on going with the black paint, probobly a primer designed for galvanized metal would do the trick. Especially now that I have the aspec lip on it would be a pain to have to go back in and repaint it.
What is the zip tie for did you epoxy the grille in? mine is just sandwiched between the grille and bumper?
As for the zip ties, I used them to temporarily hold the mesh down while the epoxy cured.
how did you get it to hold...did u just used zip ties? or did you use that silicon adhesive like the other thread had said ? ( I forgot whos it was, but there was someones thread with mesh grill)
Originally Posted by JJaber06
MaFreCoLa, that looks really good....I'm about to do it!
It is very easy to do, but the whole epoxy process is not necessary, if you cut the mesh to 3.5" tall and then trim it at the ends to be flush with the plastic grille profile you are done! push the assembly back into the bumper and the plastic frame will sandwich the mesh and hold it securely.
There's a way to take out the lower grills without taking the bumper off (as someone mentioned), can anybody help me out with that? I can't seem to unclip the top left two clips from the bumper. Can anyone provide me with some helpful information before I yank it out and break one of those clips? Any visual aid would be nice.
The DealerMan
There is no need to remove the bumper at all to do this. The two clips farthest to the outside of the car are the most difficult to get. If you have long enough arms you can actually work your hand all the way back to the clips from below the bumper and then release them. you can also use a very thin piece of plastic like a credit card and slide it in from the front and push hard till it pops the clip up and releases it.. I have done both, the credit card requires you to push really hard and feels like your gonna break something. It takes some time to work your hand all the way back there and its uncomfortable but you can get to them.
Btw. anyone know how much that piece costs to replace?
Thank you for the advice. I'm going to try this tomorrow in the morning.
For those with an Aspec lip, you HAVE to remove the lip in order to access the lower grills. Unless you bend back the lip with a crow bar...
Check this thread out...
https://acurazine.com/forums/show...highlight=grill
sockr1
10-01-2015 01:31 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
