04 TL Oil Analysis
Old 07-30-2005, 10:51 PM
SodaLuvr's Avatar
Thumbs up 04 TL Oil Analysis
2004 TL, mostly city driving with a few long trips.
For the 6500 mi. interval, 5 oz of LC was used initially as recommended, then 5 ounces was also added 3500 mi into the interval for curiosity's sake. FP was used at about every other fill-up.
Absolutely outstanding results. If the owner can use FP at every fill-up, insolubles could probably be dropped to 0.3. It seems possible that the wear is "this good" because the LC was able to clean, while the oil was allowed to lubricate. Undoubtedly, the LC helped stabilize the TBN helped maintain a high flashpoint, >400F.
Blackstone did the test with the excellent Terry Dyson interpretation. Cannot post Terry's comments since they're proprietary.
Will sample next time at 10K. Refilled with the last 5 quarts of Amsoil XL 5w-20 API SL/ILSAC GF-3. LC dosage has been upped to 2 oz/quart, then 1oz/1,000 miles.
Michael
Old 07-30-2005, 11:51 PM
nfnsquared's Avatar
Received 1,794 Likes on 1,347 Posts
LC???? FP????
Old 07-31-2005, 12:37 AM
caball88's Avatar
LC???? FP????
yeah i'm confused as hell here as well when they start posting oil analysis info. 2 or 3 people on this board must know what they are talking about.
Old 07-31-2005, 06:44 AM
JetJock's Avatar
LC=Lube Control FP=Fuel Power or something like that. Ask Michael...he'll give you the story about this stuff. I'm considering using this stuff. It's not cheap but with oil analysis results like the one in this post, it might just be enough to get me started using the stuff.
Old 07-31-2005, 07:38 AM
nfnsquared's Avatar
Only problemm is that he didn't run a control analysis with no LC or FP added for comparison. It'd be nice to see the difference.
Old 07-31-2005, 07:39 AM
Registered Member
SouthernBoy's Avatar
To Michael;
Would you expect Mobil 1 to give similar (as in very close) results?
Old 07-31-2005, 09:47 AM
scrb09's Avatar
What is it? where do you get it? how does it help?
Old 07-31-2005, 11:15 AM
SodaLuvr's Avatar
To everyone:
LC is Lube Control, and FP is Fuel Power. The correct abbreviations for them is supposed to be LC20 and FP60, for Lube Control and Fuel Power, respectively.
As you can see, the LC20 stabilized the TBN and allowed it to stay strong. It also helped clean while the oil was allowed to lubricate, which may have contributed to the low wear. Notice how the wear did not increase even though the oil was in use longer, but that is mainly due to break-in.
The FP60 helped keep the solids level down, and kept combustion efficiency up. The LC20 helped the flashpoint stay >400F, which is ideal for volatility control.
Without the LC20 and the FP60, the flashpoint would not have stayed as high, nor will the TBN be as strong. Solids levels may be slightly higher without the FP60. If FP60 had been used at every fill-up, the insolubles level would be at 0.3% or lower.
Southernboy, M1 probably would not have performed as well here. The Fe (Iron, valvetrain wear) would not have been as low with M1, which is M1's main weakness with its chemistry. In addition, I doubt that the TBN retention would be as good with M1, though that can be somewhat misleading as some oil will tend to show a higher TBN by design while it may not be neutralizing acids as well as another oil, for example, that may be showing a lower TBN. (Hint: Redline)
I'm interested in seeing how the most recent API SM version of this oil will do. With the reduction in Ca and P levels, I don't know if it'll provide the same service life.
You can only get LC20 and FP60 at their manufacturer's website, www.lubecontrol.com
Michael
Old 07-31-2005, 11:23 AM
nfnsquared's Avatar
To everyone:
Michael
Michael,
All this would be more meaningful if it was compared to a control analysis done on an oil change from the same car without LC or FP additives.
Old 07-31-2005, 11:24 AM
SodaLuvr's Avatar
The last UOA had no LC, but only some FP.
Michael
Old 07-31-2005, 12:23 PM
SodaLuvr's Avatar
BTW, I'd like to add that the MID read 20% when this sample was taken.
Michael
Old 07-31-2005, 12:56 PM
SodaLuvr's Avatar
Michael
I mean, the 3,450 mi run had NO LC20.
Michael
Old 07-31-2005, 06:00 PM
Not a Blowhole
Road Rage's Avatar
I like that Terry's comments are "proprietary". I need to start doing that with the RR Journals - this gratuitous sharing must stop now!
Maybe if folks had to "pay for it", it would mean mroe?
Old 08-01-2005, 04:51 AM
HMFIC
KilroyR1's Avatar
Educating the masses is your reward.
Old 08-01-2005, 10:39 AM
Licking Platters Clean
JackSprat01's Avatar
Yeah, I think that's how Terry puts food on his table. Certainly not that RR's info is less valuable. Not "cheap," just less expensive!
Old 08-01-2005, 02:16 PM
SodaLuvr's Avatar
RR, Jack, and Kilroy,
No offense to my pal RR here, but I think none of here can match Terry's knowledge nor his experience with lubricants in the field. His knowledge on this subject is outstanding.
No Jack, Terry is wise enough to use Dyson Analysis as his "side job," not his main source of income.
Michael
Old 08-01-2005, 07:24 PM
Not a Blowhole
Road Rage's Avatar
The Journals cover much more than oil - we have more oil analysis than we need as it is.
Old 08-01-2005, 09:30 PM
HMFIC
KilroyR1's Avatar
Why pay for fantastic information when great information is free?
Where is that "beating a dead horse" smiley?
I'm down to 30% life on my Motorcraft 5W20 blend. When it get's down to 20%, I'll change it and have an analysis done to see if my driving and the maintenance computer are on the same page.
I'll post results so you guys can give me an idea of motor's condition. It better be good with only about 16,000 miles!
Cheers,
Don
Old 08-01-2005, 09:38 PM
And no offense to the Terry worshippers here (Michael) it's a good thing it's his second job because I certainly wouldn't pay the extra for his 20 second blurb that he THEN doesn't want you to post even though you already PAID FOR THE GODDAM THING. He knows oil, true, but that's a bit much for my taste.
Old 08-08-2005, 09:22 PM
ChuckDu's Avatar
Michael,
Based on my driving style, the Oil Life Indicator is reaching 15% at about 5500 miles since the last oil change. The ugly "Service Due Soon" message is a great motivator to get my butt under the car and do an oil change asap. So with 5500 miles on the oil, if a $2/qt oil (Motorcraft 5w-20 Synblend) and a $4.25 oil filter (Filtech) results in a Blackstone UOA with good results, is there any reason to spend $5/qt of oil and $10-$15 on a better oil filter?
I'm just about ready to do my 3rd oil change at 13,500 miles and am expecting that this UOA possibly showing a bit of elevated iron and copper that are still being flushed out from break-in. After the next oil change at 19,500 miles or so, I expect a "clean" UOA . I'll be sure to post a copy to see how it compares with the Amsoil report you recently posted. This should be in the mid-October time frame.
By the way, isn't a Copper level of 27 ppm a bit high for 16,000 miles? My 7,500 mile report shows the universal average for "this type of engine" to be 11ppm.
Thanks for all your advice and the time you take to help us out.
Old 08-08-2005, 09:33 PM
SodaLuvr's Avatar
Chuck,
I'll comment more later, but the Cu is normal for a Honda V6 engine. (20-30ppm is within specs)
Michael
Old 08-09-2005, 04:04 PM
Parker75's Avatar
Normal or optimal range of values requested
Michael,
Thanks for sharing this table with us.
I'm new at reading these results so I would like to suggest that you provide a normal or optimal range for each parameter line in the table.
Old 08-10-2005, 03:48 PM
SodaLuvr's Avatar
Parker,
Al= Typically 1/3 of Iron (Fe) wear. 3-4ppm is a normal reading for most 3-7K drains.
Cr=Should be 1ppm, maybe 2 ppm
Fe= 1-2ppm/1,000 miles, may be elevated by Fuel, dirt ingestion, damaged bearing overlay, or reaction with the oil's additives. (Additive clash)
Cu=Normally in most cars, its supposed to be 1/3 of Iron wear. Honda V6 engines are an exception, and 20-30ppm is normal due to some parts in the engine.
Pb= Should be 1-2ppm in a well broken-in engine.
Additives vary by oil to an extent, so I won't comment on those.
Michael
Old 08-10-2005, 03:54 PM
SodaLuvr's Avatar
Originally Posted by ChuckDu
Michael,
MC 5w-20/Filtech filter may provide the same results, but it won't be able to last as long as the Amsoil.
The Cu level will drop to around 10-15ppm when the engine has >50,000 miles on it; even at its high levels, it is not affecting other values thus I wouldn't worry about it, it is normal for this engine.
IMO, Mobil 1 is actually one of my last choices for extended drains. It is lame in reducing valvetrain wear, and has very limited solvency. Schaeffer's #704 5w-20 would actually perform better than Mobil 1, at about 3/4 of the cost.
Michael
Old 08-10-2005, 04:22 PM
Hugh9269's Avatar
I just changed my oil for the first time, it was free by the dealer, i provided a Mobil 1 oil filter, since i could not find a PureOne at the local auto parts mart. Should that be good with standard Honda oil for first change?
Old 08-10-2005, 04:35 PM
Administrator
Ron A's Avatar
Received 1,003 Likes on 573 Posts
Is it ok to mix oil of various viscosities? I have a quart of 5W20 and about 1 1/2 quarts 5W30, and I plan on going back to 10W30 which I think will be fine here in Florida.
If I mix them, will they just average themselves out and become something in between the lowest and highest numbers? They are all the same brand.
Old 08-10-2005, 05:52 PM
SodaLuvr's Avatar
Mixing? No problem. Use the viscosity index calculator to calculate the viscosity. I'd say that it'll come out to be a light 30wt, probably in the low 10cst range.
I'd use 5w-20, but then again, I'm not a big fan of Mobil 1 either.
Micahel
Old 08-10-2005, 05:54 PM
SodaLuvr's Avatar
Hugh,
M1 Oil Filter with the Honda, Mobil Clean 5000 if its the SM version, is fine.
The oil filter isn't as important as some people think it is, and even I may have overemphasized it in the past. It just has to not interfere with flow, and not leak.
FFs have little to no effect on wear, anyway.
Michael
Old 08-10-2005, 06:36 PM
Administrator
Ron A's Avatar
Thanks Michael. You probably figured out that I have all these leftovers because I can't decide what to use, and maybe I will use one of the other weights. It's Quaker State, by the way. I've been driving a long time, and started out with Valvoline, but then I couldn't find it after one of my many moves from being in the Air Force, so I switched to QS and it has always served me well.
Old 08-11-2005, 06:49 AM
Ron, do you have a beater or something to mix coctails in? I use up my extra quarts of ANYTHING and throw them in our Montero. And also, unless it's a really nice cocktail, I'd never let it go past 5k, especially if it's faker state, although I think they have a 4x4 oil or something that is decent now. Also, sorry if I missed this in another thread but why go to 10w30? Remember, even in Canada the operating temp is the same inside the engine. Even if you get a jump on the startup temp 10w30 won't do anything extra for you except pork you at the gas pump. If you REALLY want to stay old school, use the 5w-30 Halvoline, but I can't think of a good reason for 10w30.
Old 08-11-2005, 08:20 AM
Administrator
Ron A's Avatar
As I said I am still thinking about which weight to use. It's been a while since I asked, but RR said the 10W30 would be ok, and there are several other members who are using it in warmer locations, but I might go to the 5W30 as you suggest. I just don't think I need 5W20.
My other car is an 87 Olds 98 with 150,000+ miles on it, which runs as good as the day I got it and doesn't use any oil between changes, so it's not really a beater. And I would rather just give those odd quarts of oil away than mix them if I thought there would be a problem.
You're right, I am old school and kind of set in my ways, but not too old to take good advice.
Old 08-11-2005, 11:43 AM
SodaLuvr's Avatar
Ron,
Test your 10w-30 Quaker State Dino after 3K, and see what the viscosity is. It'll be a 20wt.
Michael
Old 08-11-2005, 12:37 PM
Administrator
Ron A's Avatar
Do you mean 20W30 or 10W20?
How about the 5W30? Will that also be a 20 weight after 3,000 miles?
I'm not being wise with these questions, but you brought up a good point and I just want to expand on it so I and probably a few others will understand your meaning better.
Old 08-11-2005, 01:50 PM
SodaLuvr's Avatar
Ron,
I mean 20wt as the 20 in 5w-20.
10w-20, if you want to put it that way. 5w-30 will not be any better, 10w-30 is already more resistant to shearing that a 5w-30 due to its smaller span, thus fewer Viscosity Improvers.
Michael
IBankMouse
06-13-2020 12:53 PM
Thuneau
10-03-2015 04:19 PM
jubikej
1G RDX Problems & Fixes
09-30-2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
Froid
09-27-2015 06:16 PM
Quick Reply: 04 TL Oil Analysis
