from 03 CL-S to 06 TL!!!
just took delievery today... 7.4 miles on odometer...
black on black navi.... 5AT.....
loving it.....
well keep u updated with how the car goes....
nice to be in a different section.. hopefully everyone is just as helpful.....
one question.. try to set up my treo 650,.... it says state phone set up, under voice commands but do i hit the voice command button steering wheel or the talk button on steering wheel cause when i use the voice command button it keeps going to setup and not phone setup??
thanks....
loving it.....
thanks....
just shows a pic of car with 4 wheels and says something like tire pressure OK, in the info screen by spedo....
what is the scoop on the new/added/ adjusted suspension? what are the specs? not sure of difference from 05?
nah theres no new suspension on the 06, well not that i've heard of. The only difference in the 06 from the 05 is the TPMS. Sucks to hear that it doesnt display the psi of each wheel like the RLs
Regions Leader
Regions Leader
loving it.....
thanks....
loving it.....
thanks....
congrats bro!!!
I dont have a bluetooth phone yet, cant help you with that one
loving it.....
thanks....
loving it.....
thanks....
Yes, he did that
loving it.....
thanks....
loving it.....
thanks....
As for the phone setup, just follow these steps
- Push the phone button on the left hand side of the steering wheel (large button with the phone on it). Your MID should say "Main Menu".
- Press the button again and say "Phone Setup"
- Then hit the button again (before or after listening for the options) and say "Pair".
- Then just make sure your BT is on your phone and make the phone look for new devices. That should get you going.
Enjoy the new ride
If you push that select button thats above the < info > button while looking at the "tire pressure OK" screen you get:
06 TSX ASM/Ebony 5AT
Originally Posted by jhan1102
iPod!!! anything new??
http://www.hondanews.com/CatID3000?m...54774&mime=asc
Oderint dum metuant.
Congrats on the new car!!
Originally Posted by Actuary
I am desperate on retrofitting TPMS now
I'm almost ready to air down my spare tire and go to discount to have em remove the tire so i can see how the sensor is mounted. If you're serious about doing it, thats enough curiousity to push me to break that tire down to find out. Like the tech at the dealer told me, its supposed to be removable. Has to be some kind of battery powered gadget, but i would be really impressed if it got its power from moving around like those kinetic watches.
06 Nav Disc
Can you tell us what version of the NAV DVD was included? Another thread said there was a new version (3.5) coming at the end of October. I would think the 2006 would have it already. I believe you can find out the version by going to "setup" screen. Trying to figure out if the 2006 TL has the updated NAV like the new Honda's, which is suppose to have many more voice commands (500 Vs 250?) and a faster processor. I'm hoping the TL has the updated Nav.
Database Version:
20050622
Software Version:
ver. 1.1100
so definately not the oct revision, not surprising though considering it was probably built in september ( I could check my door sticker ).
Team Anthracite Member
n1976,
you'll probably get the updated disc sent to you for free. I bought my car in October of last year and they sent me the latest update in February for free.
they did have 05's in stock when i shopped, saw about 7 on lot and 18 at there other lot, only about 6 with navi left. and didnt have the color combo i wanted and couldnt find it either so we went with an 06 which they had the color combo i wanted in stock.....
If you have to buy it, it looks like $180.00. There is an Acura site https://iweb.alpine-usa.com/Acuradvdsales/naviorder.php that sells it. The latest version according to this Acura site is 3.40, so the numbers you were able to see must not be the revision of the DVD.
Found this on another thread under the NAV thread ....The easy way is to check the DVD - is in the trunk and should pop right out like a normal CD ROM. Car power should be on to do this. The two keys are the color and version.
2005TL(6MT)
Was your CL-S an 6MT or 5AT? And what do you think of the stock TL suspension compared to the CL-S?
I traded in my 2001 CL-S (5AT, the only offering) for the 2005 TL Navi at the end of July. I liked the softer ride the TL offered over the CL-S but hated the bounce, squat and nose drive on bumps, acceleration and hard braking. I installed the A-Spec suspension last weekend to improve these things. The handling is much improved but of course the ride is little harder (not bad though). It is similar to the CL-S now. I'm not sure if it handles better than the CL-S with the A-Spec suspension since I haven't pushed very hard. The wider tires on the TL should help here. The TL 6MT is a totally different feel than the CL-S 5AT.
I had the 03' CL-S with 5AT, the TL suspension is a little smoother(but handles just as good to me) and still getting used to quieter exhaust, but it's nice being queiter as I get older, I will leave the suspesnsion on the TL alone, its fine with me, the CL-S had 215 and this one has 235 wide tires, and with the navi got the Michelin tires instead of the Bridgestones.... the Michelin's are the same model as the CL-S which I liked... the cabin does seem to be quieter than the CL-S for city and highway driving so far... not that the CL-S was loud.... also, i am not experiencing the rattles that I have heard so much about from the 04 and 05's so far, which is nice....... and I did hear the rattles from the back deck in July when I had the 05 TL as a loaner(which may not be the best test but....)
I don't know why u get different tires just cause of the navi...... but am happy with it cause the problems I read about the EL42's......
and why front brembo's brakes only because of 6MT?
the only thing I plan to do to this car is a 35 or 20% tint.... but for now nothing.... the CL-S I did 15% all around and 45 on whole windshield... I just like the class/luxury of this car and don't wanna screw up that look... I also noticed they took all the chrome trim away and replaced it with black from the 03' bodies.....
so far all i have to say....
thanks
thanks
2005TL(6MT)
I agree with your conclusions. The TL is very quiet. The 6MT is a little difficult to let out the clutch just by listening to the engine since it's so quiet. It lacks the wide open throttle roar of the CL-S.
The 6MT has heavier swaybars and Brembo front brakes(lots of brake dust). I've seen the 6MT sometimes listed as "performance" at online parts stores when differentiating the 6MT and the 5AT.
Overlord - Team Abyss
it says on mine -
Database Version:
20050622
Software Version:
ver. 1.1100
Database Version:
20050622
Software Version:
ver. 1.1100
This is a common way to number things. I'm sure many of you knew or figured this out. But I thought I would post it anyway.
Pimpin da TL in Orlando..
congrats... and enjoy her....... 06 are here... that means..... 07 Type S!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!! is coming soon.....
now they say that all the lights are LED( 3rd brake light, tail lights, front parking lights, and side front and rear parking lights) but it looks like the front and rear turn signals have regular light bulbs in them??
Originally Posted by zax123
n1976,
also, if i don't put on my seat belt right away, which i usually do use it, how can i make it so that light doesnt flash in the info screen and that beeping stops?
I want a tire pressure monitor . congrats on your ride though!
really dont know yet, following the break-in and not going over 4k rpm still..... i like the way the TL pulls though.... and quieter exhaust than CL-s......
