Help with Airbag Light
Old Aug 14, 2018 | 09:45 PM
Ysl_Sly's Avatar
This light randomly popped up RLX on my dash, any suggestions?
Old Aug 15, 2018 | 08:27 AM
kingofire's Avatar
Disconnect the battery for 15 minutes and the message should go away if everything is good with your airbag system.
Did you have a dead battery recently? I ask because sometimes a faulty battery will also trigger the SRS message. Its a Honda thing.
Old Aug 15, 2018 | 01:57 PM
Ysl_Sly's Avatar
i will try that thank you, & the light did pop up when the car couldn’t start, not sure if it was a battery problem or starter problem, because it made a weird noise like it was trying to start but it couldn’t until i tried it a couple of times then it started that’s when that light popped up.
Old Aug 15, 2018 | 02:01 PM
kingofire's Avatar
You probably have a bad battery then. I would definitely have the battery tested and most likely replaced.
Old Aug 17, 2018 | 11:36 AM
Ysl_Sly's Avatar
thanks man i did it light is still on which is crazy because if you look at my other post i had random lights popping up on my dash they disappeared and never came back. So idk wats wrong
Old Aug 19, 2018 | 08:26 AM
kingofire's Avatar
Did you do a battery load test? If you did and the battery is still serviceable then most likely you'll need to take it to the dealer to diagnose. You could also peruse an independent Honda mechanic if you don't have the extended warranty and save some $$$.
Rhop09
1G TSX Problems & Fixes
Apr 8, 2018 10:47 AM
Billu99tl
2G TSX Problems & Fixes
May 26, 2016 03:26 AM
bluesolara
Nov 27, 2013 02:55 AM
n3o
May 5, 2010 03:03 PM
