AM Radio
Old Apr 8, 2014 | 08:34 PM
getakey's Avatar
AM Radio
I listen to a AM news radio station during morning commute. The sound varies going in and out of a deeper sound and back to a hard to describe, but off sounding sound. Every other source sound fine. It seems like it is trying to adjust the sound, but I cannot see any setting that can be turned off that makes sense.
At first I thought it might be interference, but it happens in places where I know signal is good.
Anyone else hearing this?
Old Apr 9, 2014 | 09:32 AM
Mike_TX's Avatar
AcurAdmirer
You know that there is SVC (speed-sensitive volume control), right?
Under Settings > Audio Settings > Sound.
Old Apr 9, 2014 | 11:06 AM
getakey's Avatar
yes - its not that
It will change back and forth when I am stopped
Old Apr 9, 2014 | 01:12 PM
Mike_TX's Avatar
AcurAdmirer
Originally Posted by getakey
yes - its not that
Hmmm. That doesn't sound right.
Old Apr 9, 2014 | 01:20 PM
getakey's Avatar
yeah - I agree. almost always starts out with a deeper, kind of hollow sound when I first turn to AM, then quickly switches to the not hollow (hard to describe). Stays in this mode most of the time, but occasionally switches back to the hollow sound for a few seconds.
Old Apr 9, 2014 | 08:25 PM
getakey's Avatar
I can consistently reproduce this. If I switch to AM talk - it comes on with a deep hollow effect for about 2 seconds and then changes. Rarely changes back to the more hollow sound, but it has happened
Now. I'm a bit more concerned because it also happened on an FM station. However, it happened during a commercial where there was talking. It changed back and forth several time during the commercial. Its noticeable, but not hugely different. Wondering if there is some kind of effect the system is trying to apply for talk versus music? Otherwise I have some issue.
Old Apr 10, 2014 | 07:44 AM
CFoote's Avatar
You don't have Surround turned on, do you? I noticed there was a Surround option in the loaner that I drove. I can't remember what menu it was under, but I think it was where the Bass/Treble stuff is.
It could also be that the radio antenna is just really lousy. Hopefully not.
Old Apr 10, 2014 | 10:31 AM
getakey's Avatar
I figured it out.
Just happened to look at the lower display when the tonal quality changed. The "HD" indicator on the station number was blinking. When it stopped blinking the tone changed back. Looks like it was having trouble with the high def signal. This also explains the startup behavior. Probably cannot lock into the HD for a couple seconds. I knew FM was broadcasting in HD, did not realize AM was. I had just not noticed the HD under the station number.
Old Apr 11, 2014 | 02:42 PM
CFoote's Avatar
There's High Def AM?? Wow, go figure!
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
