Used RLX Hybrids
Used RLX Hybrids
Beginning to see some great bargins on used RLX Hybrids, low miles and everything. My concern is how well does the dual system age? Are there problems with batteries that will need replacing down the road?
andy
Listen to this guy ^^^^^^ I have about 45k on my 2014 and no maintenance other than A and B services per the maintenance minder. I think at this point hybrid batteries/ longevity are a pretty known commodity since Prius came out a while ago.
Only odd problem was not being able to diagnose at a distance that the only thing wrong was a bad 12-volt battery, nothing to do with the 250-volt Sport Hybrid system.
I have roughly 35,000 miles on my 2015 SH and knock on wood, it's been a very reliable car - with nothing outside of routine maintenance, which was fully covered under the complimentary no charge maintenance program.
12v battery, wiper blades, and tires. I got new front brakes recently but they were not worn out (pads), but the front rotors were warped. Could have lived with it, but chose not to. To be honest with about 75,000 miles on the car to have nearly new pads on the vehicle at that time is a testament to the longevity and efficiency of the hybrid battery system. Rear rotors and pads are original and are looking very good at this point. It would be unreasonable to expect anything more from a car regarding reliability and overall wear. It still drives and looks like new. You would never guess the mileage on it if you saw it.
Others can correct me if I'm wrong, but I believe that the lithium ion hybrid battery and associated systems are covered by an 8 year warranty which should provide some peace of mind. Also, Acura has an exchange program for the lithium ion hybrid battery whereby you can trade your old unit for a reconditioned one (new lithium ion cells) for a fee that I believe is around $1,500. If I recall, the program is listed in the TSB thread. So, if and when the battery does require replacement, a cost of $1500 isn't a crazy amount considering what a timing belt change can cost these days and considering that the new refurbished battery will be good for at least another 8 - 10 years,
Just my two cents
Just my two cents
We just purchased an '18 RLX SH-AWD Advanced as a CPO with only 1300 miles on it. It came with a full CPO warranty plus the remainder of the factory warranty, and we STILL purchased an ad-on warranty that would cover more than the extended CPO powertrain warranty. Why? Nobody has 7-10 year experience with the 3-motor hybrid system in these vehicles, and since we spent a fair chunk of cash on the vehicle, we wanted to be sure we didn't get caught down the road with an expense for a repair that was unpredictable. We love the car, and decided to make sure we didn't have to worry about the "what if?" question down the road. That'd be my advice....
andy
andy
I keep cars for more than 10 years typically, so I jumped on the deal!!
Add Acura Care
If you buy new or used and you are within factory warranty, you can add Acura Care anytime.
https://www.curryacuracare.com/
CPO is different.
CPO is different.
JSakaBuck
3G RLX (2013+)
Feb 28, 2017 07:17 AM
krava
3G RLX (2013+)
33
Apr 11, 2015 08:04 AM
