iPhone i7
Old Sep 21, 2016 | 01:09 PM
Jim 2004's Avatar
iPhone i7
Anyone having issues pairing an i7? I'm thinking about buying one.
Old Sep 21, 2016 | 07:11 PM
bbrouillette's Avatar
Just did mine a few minutes ago. The replace device option did not find the new phone, but once I deleted the old phone and used add device it paired up in just a few seconds.
Old Sep 27, 2016 | 09:18 PM
bigred123's Avatar
iPhone 7 Plus user here....no issues. I didn't know about the replace device option - I just paired the new one and deleted the old one.
Old Sep 28, 2016 | 08:51 AM
pgeorg's Avatar
Same here, just deleted the old one and paired as a new phone.
Everything is working as it should.
Old Sep 29, 2016 | 03:39 PM
fsmith's Avatar
Uh-oh. Some trouble is in fact brewing with the iPhone 7 and at least some car Bluetooth systems (which I think are generally made by third parties, not the car companies themselves).
iPhone 7 and BMW Owners Experiencing Bluetooth Audio Issues - Mac Rumors
Old Oct 1, 2016 | 10:29 AM
CadiGTi's Avatar
2020 Acura RLX Advance
For what it is worth, I have the iPhone 7 and a prior gen RL, a 2012 RL. I have only had the phone a week, but so far HFL link seems to be working well and so is bluetooth music streaming. There do appear to be other bugs/issues with the IOS 10 update relative to the phone in general. Hopefully Apple gets them worked out sooner than later.
Old Oct 2, 2016 | 04:10 PM
neuronbob's Avatar
I'm having issues on my iP6+ since the iOS 10 upgrade. I don't think this is iP7-specific. If I use one of my favorites on the phone, or dial from the phone, the Transfer button on the upper screen won't work until several seconds into the call. If I dial using the phone button on the steering wheel, or the car's phone app, all is well. It's pretty annoying.
Old Oct 2, 2016 | 04:51 PM
pgeorg's Avatar
I will try to duplicate tomorrow.....
Just a thought: did you try to delete, restart and re-pair since you upgraded to iOS 10?
Old Oct 2, 2016 | 06:45 PM
George Knighton's Avatar
Grandpa
I've had an unusual issue with a voice call and an iPhone 7 Plus on 10.0.2.
It's difficult to be sure what the problem was, though, because of a number of coincidences including a one-bar signal at the other end, and other issues. After switching to the handset, there was still an occasional issue with the call.
I'll try to zero in on things during my commute tomorrow.
Old Oct 2, 2016 | 07:09 PM
pgeorg's Avatar
iOS 10 and/or iPhone 7 are having some signal problems (something to do with the modem), especially the Verizon Wireless one....something you should keep in mind, also.
Old Oct 3, 2016 | 10:37 AM
SipsAcura's Avatar
Yes I am having a pairing issue I have an Acura 2008 TL and I have the iPhone 7 / iOS 10
Old Oct 4, 2016 | 03:16 PM
pgeorg's Avatar
Mine does not do that, tried it 3 times dialing from the phone itself. iPhone 7, iOS 10.0.2
Maybe deleting, restarting, and re-pairing, would fix this specific issue?
Old Oct 4, 2016 | 09:30 PM
Grandpa
I've had a few more instances with the 7 Plus whereby the person on the other end hears me crystal clear, but I have difficulty hearing the person on my end.
Happens on AT&T network, *not* on AT&T WiFi.
Might have three or four balls of signal when this is happening.
Caller sounds garbled, barely intelligible, and switching between Bluetooth and the handset does not help.
Old Oct 11, 2016 | 07:06 AM
Grandpa
(1) You get used to HD Voice after having calls that use HD Voice. In consequence of this, a call between your iPhone and another type of device, or a land line, will sound bad enough to be annoying. It won't matter if you're using the iPhone to your ear, or something else, it just won't sound good compared to iPhone-to-iPhone HD Voice.
(2) The way that the iPhone 7 Plus communicates with my car via Bluetooth just isn't as good as the 6S Plus was. I can't imagine why this would be. The voice seems to go through the centre front speaker, and it sounds like the way a speaker would sound if it's got a little crack in the cone...despite the fact that the same speaker works fine with Krell Audio.
I know it's not going to be possible to get a perfect call or HD Voice over a Bluetooth that was designed at least five years ago, but it's really not good. It's okay if you just want to transmit some information quickly, but it is not pleasant to hold a long conversation.
(3) I believe that the 7 Plus must have a different LTE modem from the 6S Plus. And it wasn't a change for the better.
I hear that data is a lot faster on this modem, but voice calls over some of the bands we use around my part of the world are just not as good.
Old Oct 11, 2016 | 09:30 AM
pgeorg's Avatar
Since you have the ATT&T model, it has the new Intel modems.....
I am under the suspicion that majority of the signal and bluetooth problems, are because of iOS10......
Old Oct 11, 2016 | 09:55 AM
Grandpa
I don't know why you think that, but if that's true then there is hope. If it's iOS 10, then they can fix that.
If it's the new modem...they might not be able to do anything like that without raising the power consumption. I guess they could be tricky and only raise the power if the device detects a handsfree or Bluetooth being used.
Old Oct 11, 2016 | 10:03 AM
pgeorg's Avatar
Main reason i say that, is that a lot of iPhone 6s running iOS 10 also have a weaker signal.
Furthermore the Verizon iPhone 7 loses its signal completely (No Service), for no apparent reason. It happens to me quite often.....
Apple has replaced some of them, but they do the same thing. They (Apple) are hinting that it is most likely a software problem.
I am hoping iOS 10.1 that is in beta right now, fixes all the signal and bluetooth issues.
Old Oct 17, 2016 | 06:51 PM
pgeorg's Avatar
George, you should update your iPhone 7 plus to 10.0.3 that was released today.....if you haven't already done so.
It is suppose to fix cellular connectivity issues......
Old Nov 24, 2016 | 07:58 PM
pgeorg's Avatar
George how is the bluetooth connection of your iPhone 7 plus now, after the last couple of iOS10 updates?
Old Nov 29, 2016 | 11:48 AM
Limelight's Avatar
Don't mean to hijack this thread - but for whatever reason, my car will not show either the contact name or phone number which is texting me - it just says I have a new message and would I like the car to read it. I have an iPhone 6+ with current OS.
My wife has a Samsung phone which displays the phone number on the car's display screen when the car says she has a new text.
Is this a setting somewhere or a limitation of the iPhone? It's kind of annoying because I have to try and decipher who is texting me without picking up my phone while driving to look.
Also, my wife can select a preset response from the car's menu and hit send. When I try that with my phone, it won't let me - I forgot exactly what it says but basically says an error occurred and the message was not sent.
Old Nov 29, 2016 | 01:18 PM
pgeorg's Avatar
Unfortunately its a limitation of iOS:-(
The same goes for the message reply.....
rmilkow
ILX Audio, Bluetooth, Electronics & Navigation
Sep 19, 2016 10:02 AM
emegge
Jul 3, 2016 11:37 PM
JTL__ACURA
Jun 29, 2016 07:16 PM
quintno
Mar 4, 2016 04:03 PM
LenDC2
1G TSX Problems & Fixes
Jan 22, 2016 11:45 AM
