Am I the only one....?
Old Mar 7, 2014 | 08:15 AM
George Knighton's Avatar
Grandpa
Am I the only one who wonders how easily this could be fitted to a regular FWD RLX Advance?
I mean, you know...nothing's really connected with levers and mechanical connections anymore, anyway....
>_<
Old Mar 7, 2014 | 08:52 AM
Mike_TX's Avatar
AcurAdmirer
But what would you hang onto when making hard right turns?
Old Mar 7, 2014 | 02:41 PM
weather's Avatar
^^ *lmao* Hopefully not his "own" gear shifter......
George...That is a good question...I believe the TLX will be equipped by such a device too....not all trims I am sure.
Old Mar 7, 2014 | 10:24 PM
Treblig's Avatar
I suspect the top line SH-AWD model will be so equipped.
Old Mar 7, 2014 | 10:29 PM
MuGen7Modulo's Avatar
▒JDM ¥ KING▒
Sounds like a great idea!
Old Mar 8, 2014 | 10:23 PM
Timmy18's Avatar
I'd rather switch ermm... swap back to the leaver.
Old Mar 9, 2014 | 06:45 AM
weather's Avatar
^^ I am sure many would agree with you. This new trend of not only removing manual transmission, and now shifters is freaking many people. Acura is not alone in this....The baby Mercedes went with this flimsy lever of the steering column and I didn't like that either. There is something about driving and holding on to the gear knob....automatic or manual.
Old Mar 9, 2014 | 09:49 AM
Mike_TX's Avatar
AcurAdmirer
To (finally) get back to George's question, I don't think any of is equipped to answer it. In fact, I still assume there is some kind of physical connection between the shift knob and the transmission, but I don't really know that.
Either way, I suspect it would be a pretty big job to do away with all the gearshift mechanism and replace it with electronics.
Old Mar 9, 2014 | 10:38 AM
Grandpa
I have a friend who is a very good psychiatrist. Would you like me to set you up?
Old Mar 9, 2014 | 10:53 AM
holografique's Avatar
Interesting looking closer at the new gear mechanism. It looks like for reverse you sorta push (or tug) back on a button or mechanism?
Old Mar 9, 2014 | 11:11 AM
frainc's Avatar
lmao
Old Mar 9, 2014 | 11:12 AM
Grandpa
Yes, that's exactly right. If you can put your car into reverse and park without looking at it now, you probably would not be able to do that with the new selector.
Some people have asked whether it would be "livable" long term. Personally, I don't think it'd bother me either way.
One day it just occurred to me that the gear shift lever in the RLX is probably not connected to anything below the console and the gear shift lever is really just a switch.
Old Mar 9, 2014 | 01:59 PM
CFoote's Avatar
I have to agree with other folks that a lever is still my preferred way of shifting -- taking the mechanicals out of cars is definitely 'different' but for me it's just another thing to break. I bet that assembly is $600-$700 alone.
Chris
Old Mar 9, 2014 | 03:19 PM
weather's Avatar
If he is a friend of yours, my best advice is to have you keep him away from me. I have so many issues, that by the time he would be done treating me, he'd be the one needing help *lol*
Old Mar 9, 2014 | 08:42 PM
Rocket_man's Avatar
Summer is Coming
>_<
My question is.... if these are only switches, why put them here? Prime realestate on the center console could be used for something else. I guess we are all used to shifters being here since they migrated 'from the column' to the center console. But they could have been placed on the dash somewhere where they would not be vulnerable to random presses or coffee/soda spills.
Old Mar 9, 2014 | 09:14 PM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
>_<
Based on past experiences converting non-navi to navi accords and some transmission work from auto to manual... the biggest challenge to do something like that is the engine harness itself. Somehow the designers have reduced a bunch of wires all over the car into just one big harness. It makes manufacturing easier I guess. So, chances are if you want to modify anything under there you'll run into problems because the existing harness doesn't have the right connectors for anything else and whatever connectors there are under the console have completely different pins than what you are looking for.
Its true, nothing is connected with levers and mechanical connections anymore but what has replaced it is far more complex and secretive (unless you have access to the electrical schematics). Don't want to discourage you from doing this, but it is not plug and play and probably will take a long long time to figure out the harness.
PS. I hope the Acura Quality Assurance people have tested how that console reacts when it comes to contact with a double-double
Old Mar 11, 2014 | 09:45 AM
Pecker's Avatar
9th Gear
I just looked at the parts diagram, there is a shifter cable that runs from the gear shift selector to the transmission. The RLX sport hybrid will be a completely electronic shift selector set up. Sorry, but the ability to swap shifter styles is not possible.
Old Mar 11, 2014 | 10:42 AM
Grandpa
Thank you for checking!
peternguyen504
Sep 13, 2008 04:15 PM
Hpdrifter
Aug 7, 2008 12:30 AM
RkFast
1G TSX Problems & Fixes
Jul 15, 2008 09:54 AM
ABP_04TL
27
Jun 4, 2008 03:02 PM
