2014 RLX passenger side view mirror
Hi everyone,
I recently purchased a 2014 Acura RLX. The passenger side view mirror has an issue. It does not want to fold in. I can hear the motor attempting to, and one day at work it even drained the battery, then I realized to turn off the option to not do that automatically when I put the car in park. Every time I start the car it is trying to work until I hit 10 mph and then it stops. The other functions of the mirror work fine. Any suggestions as to what could help resolve this issue. I can live without the folding mirrors, the noise is just irritating to listen to. Thanks in advance.
MarQuis2005 (08-11-2022)
Sounds like might have worn gear or broken mirror assembly. If that's the case, just replace the entire mirror assembly with the non-advanced model. 2016 and up advanced model got surround camera build in. This will make life easier
The following 2 users liked this post by psheu:
Davefandrsn (12-20-2021),
Hi everyone,
I have the same exact issue with both side mirrors. What solution did you come up with?
I replaced the mirror with a good used unit as new aren’t available anymore. Can be pretty spendy for a used part but was worth it. Could also unplug the mirror but if you live in a cold climate, could be an issue in the winter with the defrost not being able to work if unplugged.
03tlCHARCOL
05-01-2012 10:37 PM
Eggplant-EX
12-03-2001 12:17 PM
