Windows Fogging
Old Jan 26, 2024 | 07:49 PM
gungho_15's Avatar
Windows Fogging
I recently bought a 2023 Platinum Elite. Roughly 2500km on it currently. When I remote start the car, and then go outside to get inside, the windshield and side windows have been completely fogged over. I need to crank the heat up to full to clear and sometimes roll the windows down to clear side windows. Anyone else having this possible issue?
Old Jan 27, 2024 | 09:04 AM
4th Acura's Avatar
Retired Geezer
Turn the recirculating button off?
Old Jan 27, 2024 | 03:40 PM
John from PA's Avatar
I take note of your location in BC. I suggest that unless needed turn the A/C off using the dash button. It is often on allowing under some conditions for frost to form in the ventilation ductwork. After the car is shut off, moisture can collect in the system. On restart fog can happen depending on the temperature. Putting on the defroster as well actually turns on the A/C so frost can reform.
I see some suggestions about making sure the recirc is off - that's a good idea but the first time you do this and turn off A/C expect lots of fogging until the ductwork dries up.
Jonesi
Technology
27
Dec 9, 2005 08:09 PM
Sturm
Apr 2, 2004 02:25 PM
Zapata
Technology
Jan 22, 2004 09:47 AM
