Windows Fogging
Windows Fogging
I recently bought a 2023 Platinum Elite. Roughly 2500km on it currently. When I remote start the car, and then go outside to get inside, the windshield and side windows have been completely fogged over. I need to crank the heat up to full to clear and sometimes roll the windows down to clear side windows. Anyone else having this possible issue?
I take note of your location in BC. I suggest that unless needed turn the A/C off using the dash button. It is often on allowing under some conditions for frost to form in the ventilation ductwork. After the car is shut off, moisture can collect in the system. On restart fog can happen depending on the temperature. Putting on the defroster as well actually turns on the A/C so frost can reform.
I see some suggestions about making sure the recirc is off - that's a good idea but the first time you do this and turn off A/C expect lots of fogging until the ductwork dries up.
TBone2004
Technology
15
03-29-2007 05:02 PM
