Wheel Radio Preset switch stuck on 2 presets
Updated with latest OTA, this happened before and just today. I have video.
Setup: Nav on big left side, FM radio on small right side. I have 15 presets saved.
every now and again (at least 4 times since Dec 18), As I’m flicking right on Steering Wheel preset switch to cycle to next preset, it will bounce back to previous preset. From that point on, it bounces back and forth between the 2 stations forever until...
... you switch left side to FM Radio and you can see all your presets.
You can make left side show FM radio by pressing right track pad to swap sides or going through the HOME button then selecting FM.
once you see all the presets, the wheel switch correctly cycles through all of the presets.
It it has never gotten stuck when FM in left side of screen. It’s only when in smaller right side.
I've encountered the same issue a couple of times with both of the last two updates. A workaround I have been using is through wheel controls I'll change the "app" to bluetooth then back to FM radio. I hope they fix this in a future update...
Yes, this is still a bug and most of the time it happens with the navigation on the big screen on the left. I have only experienced twice since the 1.1.2 update. at around 2/17.
This happens every other day with the 1.0.7.
Was happening a lot before the last update. Haven't experienced it since. I'm still having the USB issue where it's stuck on 'initializing' unless I unplug and re-plug it every time. I've tried ipod and several USB sticks and they are all doing it.
noblegreenTLS
1G TSX Problems & Fixes
Aug 25, 2007 03:13 PM
stanwelks
Nov 19, 2006 02:25 AM
